Can't release the retaining clips securing the main top of my whirlpool cabrio
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
  • 24 Answers
SOURCE: How do I remove the top panel of the Whirlpool Cabrio washing mac
To gain access to a Cabrio washer, use a putty knife to press inward on the 2 spring clips located where the washer top meets the washer's front/side wrap around case. Standing in front of the washer, measure approximately 3 inches inward from the outside of the case. It helps if you get eye level with the line where the top meets the case and shine a flashlight in the crack. You should be able to see the clips. Press in on both of them and the top should lift.
Posted on Jun 05, 2010
Testimonial: "Great! That did the trick. Thanks. "
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: display shows F1 top load cabrio whirlpool washer
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
Posted on Sep 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio top loader not starting properly
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%^
Posted on Sep 21, 2010
How do I get to the belt to replace it? Crosley CDG6000W dryer Rev 10 Serial # 10178386WH
You have to turn the drier upside down and work thru the bottom.
Sep 15, 2011 | Dryers
I lost Power from a Thunder Storm and now my Whirlpool Cabrio top loader won't open
Thats sounds as if the lock asm is stuck. As soon as the power went off the lock would have de-energized and should have opened.
Too check the lacth for sticking open the top by placing a putty knife in the seam between the top/front cabinet panel at the corners and push in to release the clips that hold the top to cabinet then raise top and see if something appears to be stuck on latch asm.
Gene
Aug 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The load finished on my whirlpool cabrio washer (topload) but the machine won't unlock the lid?
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
May 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du code
Here is a link for trouble shooting your machine https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It takes a while for this page to load ... and ... you may already have this information in your hand book.
I'm sorry, this is the best I can do with this question. I'm sure someone else will come along with a "key" that will get you up on the highway again. There are lots of tallented volunteers here at FixYa.com
Thanks for your interest in FixYa.com
Nov 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Door wont open on Whirlpool washer cabrio display says du
To Access/replace the switch:
#1
#2
#3
#4
#5
#6
Jan 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Two dollar coin fell into a space between agitator and a drum.
you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
Nov 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio gives intermittent F 51 code.
lean washer backward ..with torx wrench remove large bolt in center of flywheel (rotor) back bolt out until you are able to pull rotor off by hand remove 4 5/16 bolts holding stator(coils) to bottom of washer tub carefully lower stator to floor pulling wire retainers from bottom of tub makes it easier..small plug with brown wires carefully hold release clip back and pull plug on and off several times (10-12 should be enough ) reassemble unit and ck...during manufacture too much flux got on contact portion of sensor board and caused poor connection at plug..by pulling plug on and off the flux will be cleaned off(had 1 today)
Aug 15, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
The Lid Lock will not engage at the start of cycle on a Whirlpool Cabrio.
bad lid lock most likly cause..clips under edge of top release top switch mounts to front edge of top and wires runs to control under console
Apr 24, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
