Question about Ovens
GE Oven 326B1230P001 - Ovens won't heat to desired input. Input 350F for top oven, it only reaches 275F, input 350F for bottom oven, it reaches 325F. All elements are in great condition and turn red when separately turned on to higher settings. Are there two separate thermostats or does this sound like a main control board issue? Or something else?
  • john Apr 24, 2014
    I experienced longer cooking times in the past so I bought an external EKCO external oven thermometer and used the same one to test both ovens on 350. Thank you for the question.
    Problem Solver:
  • 18 Answers
FIRST HOW ARE YOU DETERMING HEAT OUT PUT WITH ONBOARD TEMP READING OR WITH A OVEN THEMOMETER THAT YOU PLACED IN OVEN EITHER WAY IT COULD BE A CALIBRATION ISSUE
Posted on Apr 23, 2014
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
  • 13 Answers
SOURCE: Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Posted on Jul 29, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: Oven/ broiler will not heat and bottom element slow to reach temp
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
JRP 15 oven showed 350F and gave preheat beeps. Frozen lasagna "cooked" 45 mins and was still almost frozen. Oven was warm inside, not hot. Bottom element glowed orange when I increased the temp setting...
The oven was obviously not heated to 350 even though this was the setting. There is a very simple proceedure to calibrate the oven. It is different on different makes of ovens. Your owners manual will give you the detail of how to reset yours. If the manual is not available, click on the following link. Hope this is helpful.
http://www.applianceaid.com/temp-change.html
Oct 05, 2009 | GE JRP15 Electric Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
Nov 06, 2007 | GE JTP20 Electric Single Oven
Ovens Logo
239 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
