Question about Furniture
Nsa30lacg compressor does not ran. check for coils resistenace and the work coil is open
  • 225 Answers
SOURCE: ice on coils
The short answer is "yes but maybe not for much longer!"
If the bucket is filling up with water it's probably working OK. Have you selected "continuous" instead of, say 60% ?
If the bucket isn't filling up with water then maybe the intake filter is clogged with fluff, preventing new moist air from getting to the cold coils and being extracted. Or maybe the fan isn't running?
I hope this info will be a useful starting point for you.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 29 Answers
SOURCE: no spark from coil
possicle bad coil or possibly bad crank sensor, when cranking look at tach and see if needle moves up a bit, if not more than likely crank sensor
Posted on Nov 16, 2008
outdoorsman5
  • 631 Answers
SOURCE: how can we check the ignitor and coil ? what are the specs?
What engine do you have? You could still hear your fuel pump running but if you haven't checked the fuel pressure you may still have a problem with your fuel pump. You should be around 38 to 44 PSI when key is turned on not running. Did you verify you are getting spark or is there nothing to the plugs? Your ignition coil resistance should be (cold 9000-15,400 ohms) Primary should be .36-.55.
Your pickup coil resistance depending whether you are California or excluding California
California is
cold- pick up coil terminals G1 & G- Ohms 125-200
cold-Pick up coil terminals G2 & G- Ohms 125-200
cold-Pick up Coil terminals NE & G- Ohms 155-250
Ex. California models
cold-Pick up coil terminals G+ & G- Ohms 185-275
Cold-Pick up coil terminals NE+ & NE- Ohms 370-550 ohms
You also need to check air gap between PIck-up Coil & Signal rotor
California is .008-.020
Except California .008-.016
Here are some of the suggestions from Mitchell books:
ENGINE CRANKS BUT FAILS TO START:
*Ensure proper spark exists from ignition system
*Ensure Fuel system performs properly (fuel pump, Fuel filter, Fuel injectors, fuel pressure regulator).
*Check engine compression, valve clearance, valve timing and timing belt (if equipped)
Check airflow meter or MAP sensor and wiring
*Check idle air control valve (if equipped) and wiring.
*Check circuit opening relay and EFI main relay.
*Check STA signal at Engine Control Modual (ECM)
*Check Engine Control Modual (ECM) and wiring.
Posted on Aug 05, 2009
  • 587 Answers
SOURCE: Dehumidifier - hot compressor / coils not cold
If the compressor's running and it's getting hot and the coil isn't getting cold, then you are probably low on refrigerant or your txv or metering device isn't working.
Posted on Aug 25, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
My portable airconditioner,dimplex dac 3400, the cool function is exactly like the fan function, It doesn't blow cold air??? Do u ever need to regas this machine at any time???
Check the condensor coil to see if it is stopped up. The duct that you run outside to vent the heat that is being removed is attached to it. Does that duct move air at all or a good amount of air?? If coil is stopped up it will restrict air. Is the compressor running? If the coil is stopped up it is likely to overheat the compressor or the compressor start components may of failed. See if you can tell if it is running. It could be a bad compressor. Typically small systems issues do not have problems with freon leaks and you should never have to add freon unless you have a leak. Is there a filter on it check to see if it is stopped up. If it has ran with a dirty filter check the cold evaporator coil to see if it is stopped up. I haven't see. That exact machine but these are basic things to look for.
Dec 10, 2015 | Heating & Cooling
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Coil on a/c compressor
If you are talking about the part behind the pulley on the compressor, its part of the clutch assembly.
You get the pulley and coil as a kit which bolts to the shaft.
Check the online auto parts stores for ac clutch.
Jul 19, 2012 | Dodge Cars & Trucks
You do understand that the compressor cycles on and off as needed to maintain system pressure?? Check and see if the clutch closing coil has 12 volts to it at the connector when it stops, if it does the clutch closing coil is defective and you will need a set of compressor tools to replace it.
Jul 19, 2012 | 1997 Dodge Caravan
I have an amana side by side ars2364aw thet suddenly stopped cooling both sides.The compressor and compressor fan opperate, but the evaporator fan by the coils inside doesn't. I tried replacing both...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Refrigerators
It kept running, clicking to try and shut off but couldn't. Freezer thawed. I shut off for a while, vacuumed coils, turned back on and it ran fine for three days, working perfectly. Next morning repeat...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 21, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
My indoor fan comes on but the compressor does not. I checked voltage, fuses and wiring and everything was ok. When I depressed the contact (single pole) the compressor would run and make cold air. When I...
as u written here that the power is their in coil voltage than check for the neutral connection of the coil ,if it potential voltage across the coil is normal change the contacts coil & buy a new one with the same potential that u have in your home.
Jul 25, 2010 | Heating & Cooling
Hi Side by side refrigerator not cooling down. Freezer seems to be not freezing. refrigerator compressor is running. Freezer damper wide open on a setting, refrigerator turned up to 10, running but not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
jkkfj
Jul 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ac compressor will not ingage it has refrigerant in it and low pressure switch is working any ideas
check the ac fuse for continuity and then check the relay that supplies power to the compressor,and then unplug the "magnetic clutch coil" that in front of the compressor and check that coil for continuity.they draw a lot of current and can burn open after time ,and also clean any connections as well, especially ground connections
Apr 06, 2010 | 1991 Ford Aerostar Extended
Amana SRD520T - appliance tripped the circuit breaker. After power had been restored the compressor ran but no cooling in freezer or fridge
With the compressor running, open the freezer and listen if the fan is running. If it is not, replace it. Most likely, this is your problem.
If it is running, turn off the refrigerator. Remove the rear panel from the freezer. Inspect the coils. If they are covered in ice, let them thaw completely. This ice will prevent the freezer and consequently, the refrigerator from getting cold.
If the fan works and the freezer coils are not cold, then I am afraid it is time for another refrigerator.
Feb 05, 2010 | Amana Refrigerators
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
