Question about Jensen Televison & Video
My Jensen 3280 was installed by Thor in my motorhome....the volume was never as loud as needed, but has faded to barely audible even with volume control maxed out...
The audio out (L and R) are connected to the home theatre system of speakers, too..but it is not loud enough to barely hear, but the same system on DVD will blast out sound.
    Champion:
  • 216 Answers
GET INTO AUDIO MENUE AND SET AS PER MANUAL.
Posted on Apr 22, 2014
Testimonial: "I can change Bass and Treble, change balance, turn the speakers off and back on, but nothing in the audio menu addresses the problem."
  • WILLANM HARVEY
    WILLANM HARVEY Apr 23, 2014
    Please ck signal path of inputs and how they are routed through amp.
SOURCE: TV Ears
if you have a satellite receiver or cable converter box get the sound there and put into home theatre.... my sony has blown audio amp and this works for me retired santa
Posted on Mar 04, 2008
MikeNJ1964
  • 398 Answers
SOURCE: volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Posted on Aug 27, 2007
MARR
  • 49 Answers
SOURCE: Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Posted on Feb 26, 2007
  • 71 Answers
SOURCE: NO SOUND
Unplug the power to the tv for couple of minutes; replug and should have sound!
Posted on Jul 19, 2008
Shuttle83
  • 1139 Answers
SOURCE: i cant hear the tv
Hello drive2darim,
OK first check you converter box, Cable TV/ Satellite TV volume control and turn it up to 100%.
Then check the menu on your TV for audio settings and set them to there default settings. This should take care of this issue.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 13, 2009
On my toshiba n305 notebook speaker sound is barely audible even at highest volume level. it is fine with earphones. tried everything. is it designed that way or something can be done? thanks
If you're on Vista/Windows 7, follow these instructions to enable Loudness Equalization. This significantly boosted the volume of my laptop speakers.
Start Menu -> Control Panel -> Hardware and Sound -> Sound
Double click on your default sound device (it will have a green check on its icon). Go to the Enhancements tab. Check Loudness Equalization, and hit apply. That should boost up any super-quiet noises.
Mar 07, 2011 | Computers & Internet
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
End of drying signal volume is extremely low
The buzzer is probably going bad and needs to be replaced. Does it get quieter when you turn down the volume, if so then its going bad..
Aug 31, 2009 | Dryers
CD's won't play in Jensen VR185
Do you have it set on mp3
Aug 11, 2009 | Car Audio & Video
How to turn the loud on??
There is an EQ and Fade/Balance menu
also if you go into the main menu of the unit and press p.Vol, there is individual volume boosters or minimizers for all your different sources (very neat)
Nov 12, 2008 | Audiovox VM9512 Car DVD Player
Jensen CD3010X Radio Problems
This happened to me too--with the same unit. I finally took it apart and found that the volume up button was shot. The tiny piece of metal that makes electronic contact had actually snapped in the middle causing contact to be made at random by bumps rattles or just about anything. Since the unit automatically comes on when the volume button is pressed, even turning it off was ineffective. So...I unsoldered one of the buttons that I never used much and soldered it where the broken volume button had been. I'm no expert, so I was rather surprised when the unit worked after i reattached it in my dash. Anyways, it was a cheap fix for a cheap--and poorly made deck. good luck
Mar 23, 2008 | Jensen CD4610 CD Player
Samsung m300 volume
for the folks that are ending their calls by closing it, you can change your settings so that it won't do that. under settings choose how you want to end the call.
Mar 14, 2008 | Samsung SPH-M500 Cellular Phone
Televison & Video Logo
46 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
