Question about Motorola RAZR Cell Phones
Motorola RAZR resetting factory settings without sim card
  • Official Brand Answer
  • 3,100 Answers
Our Android Motorola Razr can be externally reset.
How do reset my DROID RAZR
Our Motorola Razr V3 cannot be reset if you forgot the PIN. You can push Menu and then try to enter t he security code 000000
Mark
Motorola Support
Posted on Jan 08, 2015
fix-shad0
  • 83 Answers
SOURCE: Razr V3: Subsidy unlock code?
Download this unlocker. Unzip it somewhere you will remember.
http://dl1.rapidshare.de/files/689909/63115315/Motorola_Unlocker.zip
1) Turn Off your phone
2) plug your phone to the PC using your mini usb cable
3) put your phone on the flash mode *,#,and power button
4) open the software
5) click on connect RFone
6) click yes
when it say done it is unlocked
This info is in motodude sig just find a post by him and you will find many links that are usefull for motorola phones.
Posted on Aug 23, 2008
  • 71 Answers
SOURCE: Replace a sim card
Replacing the Sim Card on a Motorola RAZR
  1. On the back of the phone you should see grooves for you to slide off like batteries on the back of a remote.
  2. Slide off the plastic cover.
  3. Remove the Battery.
  4. You should now see the Sim card.
  5. Slide the Sim Card out / Lift up the hatch and take it out.
  6. Slide the other one in / Insert the new one and close the hatch until you hear a slight noise of it clipping in.
Posted on Oct 01, 2008
em0ti0n1
  • 35 Answers
SOURCE: how can i restore factory setting in motorola v3i without sim car
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Posted on Jan 09, 2009
133712ap3
  • 22 Answers
SOURCE: Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Posted on Jun 24, 2009
rylee_smith
  • 8619 Answers
SOURCE: have motorola razr V3, how do I transfer text messages to sim rea
Hi
Thanks for using FixYa. If you have Motorola phone tools installed in your system, then you can directly copy the messages from the phone to your Computer. And, if you are unable to see the messages through the SIM card reader then the messages would be in the phone and not SIM.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 12, 2009
Sim card not working on xt912
try a soft reset on ur phone then when its done go into ur options and go to mount sd card and then put it back in and see if that works if it doesnt you either have to buy a new sim card if that doesnt work factory reset your phone if that doesnt work your sim card port is probly fried and has to be fixed
Jun 02, 2012 | Motorola Mobility Droid RaZr XT912 16GB...
Insert SIM card displayed and SIM card i in
FOR INSERT SIM:Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using iPhone solution. This problem is caused by Firmware problem and Hardware problem as well.
OR:
New Software Reinstall in the Phone.
thanks.
Jul 08, 2010 | Motorola Mobility RAZR V3
How ro insert a sim card in motorola razr v3m?
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using IPA solution. This problem is caused by Firmware problem and Hardware problem as well. Good luck.
Jun 23, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How to unlock a razor without no sim card
You will need to obtain an unlock code. Unfortunately you will have to pay a few bucks, it may be cheaper then buying a new phone.
Nov 24, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How can i restore factory setting in motorola v3i without sim card
Master Reset
Master Clear
Caution:
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola v3i insert sim card
clean the sim card first and then the sim base of the phone then restore factory settings it will work
Jan 08, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola 3v razr - non start up
hi u need to flash yr phone with a new software, as the current one is maybe corrupted... factory restore or reset wouldnt fix that problems just flash with RSD and tht should do the trick....
Jun 20, 2008 | Motorola Mobility RAZR V3
Trouble with sim???
probably. try setting your phone to its factory settings.. if nothing happens maybe you purchased a defective phone...
hope theirs a warranty included in your purchased...
Oct 08, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
294 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
