Question about Home
Redring selectronic extra shower
Shower turning on , but no water coming out and then shower turns off , the shower is selectronic rediring
  • 68 Answers
SOURCE: Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil
www.redring.co.uk
http://www.protimbathrooms.ie/downloads/pdf/RedringBrochure.pdf Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
http://www.applied-energy.com/clientfiles/File/manuals/redring/Powerstream%20Instructions.pdf
Posted on Dec 28, 2008
Bati99
  • 88 Answers
SOURCE: Water not hot enough coming from my power shower
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
meBNme
  • 334 Answers
SOURCE: Shower push button shots water.
The valve needs to be rebuilt, replacing the washers and stems.
Posted on Aug 25, 2009
  • 67 Answers
SOURCE: Redring 3205 wont turn to cold - when control
Take a look at the .pdf document on their site. There will be adjustments within the unit that will assist you in adjusting the tempature. They advise that there could be seasonal adjustments that would need to be completed. I've assumed your model is the Activa 320S as I could not find a redring 3205. Good Luck.
http://www.applied-energy.com/clientfiles/File/manuals/redring/Active%20320S%20Instruction%20Booklet.pdf
Posted on Jul 30, 2010
leroywolff
  • 42 Answers
SOURCE: We have Delta brand tub/shower fixtures, the one
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Posted on Nov 05, 2010
Selectronic redring shower powering up , no water coming out and then turns off after approx 10 seconds
There are some troubleshooting actions mentioned on page 6 and 7 of the manual at this site
http://www.aroundtownflats.com/manuals/Shower%20Manuals/Redring/New%20Selectronic%20Instructions.pdf
The shower is designed to turn off within 30 secs if there is no water flowing through. The issue is why does water flow stop.
It can happen if shower is in overheat shutdown. Need to find if temperature setting is too high. There is a purge sequence to overcome this. See manual.
Apr 21, 2014 | Home
How to get lock off temp control off my shower redring selectronic extra
my redring keeps reverting to number one whatever i do help me please
Feb 04, 2013 | Home
Only cold water coming out of Redring digitemp shower
The temperature sensor in the unit is not functioning. It needs to be replaced!
Jan 14, 2013 | Home
I have redring expression 500, the power is on but no water coming through, no noise from the shower. could this be the solenoid valve
Replace the shower unit.There never worth repairing after five years use.You could end up paying £80 for a plumber and £60 for a part and something else goes in 6 months
Aug 06, 2010 | Home
Jun 29, 2010 | Home
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
Apr 12, 2009 | Home
Hello philipknowle,
www.redring.co.uk
Dec 28, 2008 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
