Question about Canon PowerShot A520 Digital Camera
Focus lever spring
Spring does not work and will not center the part, must do it manually in order to take a picture.
  • 1,162 Answers
I would venture to take it apart and see if you can do the repair yourself. Hardly a store I know of will even take a point an shoot camera apart today and work on them. If you find one make sure the price is right before letting them check it out. It may not be repairable. I have taken several cameras apart, purchased off ebay. SOme I wish I had never touched, and some were very easy to fix. It takes small tools and time. Cameras are so cheap today you may just want a new one, and features are amamzing . I will add that if you dont document everything as you go you will never get it back together. The most frustrating part is to get there and see a broken part you cant purchase and no way to glue it back because its so small you cant. Good luck
Posted on Feb 01, 2015
72 superbug/ vw clutch cable lever spring installation?
u need a repair manual or go to library sec629 for rebuild books
Nov 22, 2012 | Cars & Trucks
Shifter lever won't return to the " center " position always. The problem is intermittent and seems to occur more in the heat. I've heard there may be something binding the mechanism....
Follow the shifter reach rod that runs from the shift lever back to a short lever on the transmission. Take the nut off and take the rod loose from this short lever. Then, move the forward like you are going to shift into low gear but don't actually shift the transmission into gear. Feel for the spring tension. Then, move the lever backwards and feel for the spring tension there. Check the shift lever and the reach rod for binding. If you don't feel the spring tension trying to return the lever back to the center, it's likely that the shifter pawl return spring is broken. This spring is what returns the shifter lever back to 'center". But,the temperature of the transmission will not change this. If the spring is broken, it's broken cold or hot. If the spring is good and there is not bind in the linkage, the problem may be in the shifter cam mechanism inside the transmission. Either way, this is an internal issue in the transmission.
Good Luck
steve
Aug 20, 2011 | 2006 Harley Davidson FLSTNI Softail Deluxe
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
Just got this bike it was unassembled. The instruction manual had a different front axle than mine. Mine has the quick release and I can't get the tire tight. I think I am putting the quick release...
on my tips and tricks page are links to owners manuals for Schwinn and Huffy. they are all the same, Those respective websites with the links have clear instructions on quick releases.
Your quick release has three parts
1. shaft with lever
2. nut
3. springs x 2
Take the lever apart, remove the nut and both springs. install one spring large side onto the shaft all the way up against the lever side, slide the shaft through the hub axle center, install the other spring on the shaft opposite the lever small side facing the hub, then screw on the nut. look to the video for the rest.
Mar 21, 2011 | TitanNet Titan Fusion Mountain Bike
2005 yamaha r6 shift lever is limp
Wish I could be there to check it. Yes, the shift return torsion spring could be broken. No, the the shift tension spring is not the same as the torsion spring. The tension spring is not the problem. It just indexes the shift drum in proper position for each gear. The stopper screw could have a broken end. The torsion spring may not be hooked in position. It could also be that the shift lever needs to be removed and the bore cleaned free of mud and well as the shift shaft. Be sure the pedal shift lever is not bound up against anything.
Jul 17, 2010 | 2005 Yamaha YZF-R6
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Mazda miata 2003 replaced rear brake pads now parking brake does not work any ideas?
Doe's the back brakes work? Is number 7 and 15 hooked up right? If they are. Try backing up and hitting brakes, This will tigjhten them up.
1 – SUPPORT PLATE
2 – RETURN SPRING
3 – ANCHOR PLATE
4 – RETURN SPRING
5 – CABLE GUIDE
6 – PARKING BRAKE LEVER
7 – ADJUSTER CABLE AND SPRING
8 – SHOE RETAINER, SPRING AND PIN
9 – SECONDARY SHOE AND LINING
10 – LEVER SPRING
11 – ADJUSTER LEVER
12 – ADJUSTER SCREW ASSEMBLY
13 – SHOE SPRING
14 – PRIMARY SHOE AND LINING
May 24, 2010 | 2003 Mazda MX-5 Miata
Focusing problem
Hi everyone.
I had the same problem with my 400D. It refused to focus. On manual focus I could take pictures though, but not on Auto focus.
What happened was I cleaned the mirror with a piece of soft cloth, the spring hooked onto the cloth and came loose.
I took my lens off, checked the mirror, found that the little spring connecting the mirror and the little glass part above the mirror was loose. Took a lot of patience and hours to get it back in. I used a pair of tweezers 2 x toothpicks and a short piece of fishing line (thin line). Go have a look at another 400D how the spring should be clipped in. I used the fishing line to hook the " L " shape of the spring back in after I lined the back part of spring up, since there is no space next to the mirror and the body of the camera.
Like I said. This takes a lot of patience and be prepared to sit for 3 to 4 hours.
It worked though.
Hope this helps.
Where can I get a service manual for the 400D ?
Jul 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Auto Focus
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that reflects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
You can also check it by aiming the camera at an object above your head with the camera pointed up since that will hold the little mirror in place by gravity. If it works pointed up the spring is the problem.
You can get the spring from Canon. The part number is CS2-6367-000. Canon's parts dept phone number is 1-732-521-7230.
CameraRepairs
Apr 22, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon PowerShot A520 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
