Ariston avd 129
Error code 07 - What is that?
3 Suggested Answers
SOURCE: F-10 error on Ariston AVD-149 front loading
looked where it didn't cost me
Posted on Sep 19, 2009
ercupa190
  • 12223 Answers
SOURCE: Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Posted on Sep 30, 2012
Aquatis AQXXF 129 h. what is the error code 08?
It means "heater relay cannot be activated". Troubleshooting guide says to tap the relays to try to unjam them. If that fails, replacement of the main control board is necessary. These washers apparently have a propensity for stuck relays on the newer units.
Aug 15, 2015 | Ariston Technologies Washing Machines
What does the error code 07 in an ariston amd 129 ?
the led flashes seven times? then pauses for 8seconds? this is how you determine the service code on a 129 there isn't a F7 code on a 129 on a 125 it's a heater relay stuck.... hope this helps~~
http://appliancejunk.com/forums/index.php?action=dlattach;topic=8959.0;...
Jul 15, 2014 | Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
Ariston h20 errors
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Potential Causes
Sep 30, 2012 | Ariston Technologies Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
