Question about Samsung Televison & Video
Getting coloured vertical lines on screen on samsungtv .sometimes no picture
Model LE40A656AIF
    Novelist:
    Scholar:
  • 89 Answers
Model LE40A656AIF is a 2008 model LCD TV that was discontinued by Samsung. Since Samsung quit making LCD TVs in 2011, I believe that yours is starting to fail. Since repairs on a discontinued item can cost nearly as much as it originally cost, I would suggest getting a new TV.
Posted on Apr 21, 2014
  • 2 more comments
  • Roy May
    Roy May Apr 27, 2014
    that issue is more then likely the T-Con board on the tv its under some mettal pieces that the speakers are attatched to easy to replace be carefull the ribon cables are easy to brake
  • Roy May
    they have them on ebay less then 50 dollars
  • Bob Edwards
    Bob Edwards Apr 27, 2014
    When people don't mention how adept they are at fixing things themselves, I answer with the easiest solution. In the solution you stated, you are correct about how easy the ribbon cables are to break and that would more than likely be something that this person could handle.
  • Bob Edwards
    Plus the cost is reasonable but you are assuming that this solution is something that the person could handle. If the person couldn't handle it and decided to go the route of replacing the board, the labor would most likely add a significant amount to the cost.
SOURCE: LG RZ-42PX11 42
Common problem. See this site -
http://www.forums.hcsd.com.au/Blah.pl?v-print/m-1175589480/
Posted on Jul 09, 2008
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
JoeO700
  • 80 Answers
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
Posted on Feb 12, 2007
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
Posted on May 26, 2009
  • 1779 Answers
SOURCE: plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Posted on Nov 23, 2009
Sony KDL43W800C 3D LED TV coloured vertical lines on the screen.
The panel is Faulty
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 24, 2016 | Sony Televison & Video
Sony faults
this could be your t-con board, but knowing sonys it most .likely your main panel meaning your screen,
Aug 17, 2014 | Sony Bravia KDL-40S4100 40 in. LCD TV
Panasonic LCD TV Modeel No: TX-26LXD8A has vertical coloured lines that change colour depending on the program/picture. It began with a vertical red line near the centre of the screen and now there is no...
Other than taking the television to a repair shop not much can be done. I recommend a new television. Excellent brands are Sony, and Samsung. Both brands are quality televisions. Best of all you can order them on Amazon.com for lower prices.
Jan 23, 2014 | Televison & Video
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
Nov 15, 2017 | Samsung SyncMaster 910MP 19" LCD Monitor
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical colour lines on laptop screen, when laptop moved screen sometimes works ok is it a big problem/
HI:
If you can test your laptop, by connecting an external monitor to it, that will tell you if it is a screen problem, or a video problem. If you get a good picture on another display, you have a problem with your lcd or inverter.
Nov 20, 2009 | Computers & Internet
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Televison & Video Logo
353 people viewed this question
Jerry Greenberg
Jerry Greenberg
