Question about Refrigerators
Frigidaire flashing 4
Ffhs2611ls1 SIDE BY SIDE FRIDGE FLASHING 4
josh1856
  • 105 Answers
SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
Posted on Jan 27, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire phsc239dsb0- temp controls
e-f relates the evaporator fan. lasttime i had that happen it was problem with the mother board located under the refrig, replaced it and all was well
Posted on Mar 17, 2008
La_C
SOURCE: fridge temp display flashing
Is the evap fan running? What is the current temp and how long has the unit been in operation
Posted on Dec 29, 2008
mc1bean
  • 3053 Answers
SOURCE: control panel number 4
Hello, There has been a couple times, Frigidaire was sending out the wrong control board in the correct box ( believe it or not it happened to me 2x ).. finally i had to call ELECTROLUX directly and had them send me the board direct to customer.. i believe that the 4 is because there is a wiring issue with one of the microswitches where the damper motor is and it will not allow the damper / control board to recognize "open" position ..I don't know how old your fridge, but in this case you should get a tech out with some testing equipment. Thanks Mike
Posted on Oct 23, 2011
richroth
  • 9472 Answers
SOURCE: We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Posted on Dec 10, 2012
Why does the fridge side of my fridgidare side by side keep flashing on 4
FFHS2622MB3 FRIGIDAIRE REFRIGERATOR Manual ...
www.searspartsdirect.com > Kitchen Appliance Parts > Frigidaire Parts
Download Manual for Model FFHS2622MB3 FRIGIDAIRE REFRIGERATOR. ... ShopFor Parts. Click a model number to find parts at Sears PartsDirect.
Jul 28, 2015 | Frigidaire Refrigerators
Frigidaire side,by side digital display flashing #4, what does,this mean....the freezer side is not warm, but nothing is staying frozen, the fridge side,is cool, but not cold
Good Morning Brett, thanks for your inquiry!
I understand that your Frigidaire refrigerator is flashing a "4" and you would like to know what that means. The "4" on your display means that there is a damper failure within your refrigerator and I would recommend checking the damper in the rear of the refrigerator to assure it is opening and closing. The damper is located in the back of your refrigerator. I would place your hand back there to assure it is blowing cold air into your refrigerator.
If the damper is not working it could be a potential issue with your damper, main control board, or wiring harness. I would then recommend performing a reset on your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Mar 31, 2015 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire refrigerator side by side if flash a number 4 on the fridge side as it is not cooling
Good Morning John, thank you for your post!
Generally, error code 4 means that the refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards!
Jan 28, 2014 | Frigidaire Refrigerators
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
Control panel number 4
Oct 23, 2011 | Frigidaire Refrigerators
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Jan 26, 2008 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
