Question about Samsung Galaxy S Advance GT-i9070 Black 8GB Android 2.3 SIM Free / Unlocked
Unlock cont g mail
Am introdus prea multe incercari de intoducere a modelului
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Posted on Jul 04, 2014
Acumulator potrivit pentru aprelia atlantic 500
Hi , Anonim pentru aceast? situa?ie a? numi dealer meu local sau de serviciu / departament piese magazin de renume ?i ?ntreba despre orice posibil? fix / testare sau p?r?i de anchet? rapid? . Dac? transportul este necesar autovehiculul la dealer sau magazin ?i au un tehnician profesionist -l ia pentru un test drive , ?n cazul ?n care este ?n stare de func?ionare , ?i v? va oferi o estimare ?n scris de repara?ii ?i r?spunde la orice ?ntreb?ri specifice pe care le ave?i cu privire la problema ta. Pentru mai multe informa?ii despre problema dvs. , v? rug?m s? vizita?i site-ul de mai jos . Mult noroc ?i au o zi frumoas? .
http://www.tradebit.com/filesharing.php/search/0/aprelia+atlantic+500
Jan 18, 2014 | Aprilia Motorcycles
Tip
Telefon lg ax 275 alltel
am si eu sa va adresez o intrebare... la telefonul de model LG AX 275 alltel *** pot sai pun cartele sim???? mam uitat si am incercat de mai multe ori dar nu am reusit... ma puteti ajuta si pe mine va rog mult ajutati-ma..
on Mar 08, 2010 | Cell Phones
Baterie potrivita aprelia atlantic500
Hi , Anonim pentru aceast? situa?ie a? numi dealer meu local sau de serviciu / departament piese magazin de renume ?i ?ntreba despre orice posibil? fix / testare sau p?r?i de anchet? rapid? . Dac? transportul este necesar autovehiculul la dealer sau magazin ?i au un tehnician profesionist -l ia pentru un test drive , ?n cazul ?n care este ?n stare de func?ionare , ?i v? va oferi o estimare ?n scris de repara?ii ?i r?spunde la orice ?ntreb?ri specifice pe care le ave?i cu privire la problema ta. Pentru mai multe informa?ii despre problema dvs. , v? rug?m s? vizita?i site-ul de mai jos . Mult noroc ?i au o zi frumoas? . DOWNLOAD 2005 Aprilia Atlantic 500
Jan 18, 2014 | 2005 Aprilia Atlantic 500
Ce ulei este bun ptentru aprilia habana
Hi , Anonim pentru aceast? situa?ie a? numi dealer meu local sau de serviciu / departament piese magazin de renume ?i ?ntreba despre orice posibil? fix / testare sau p?r?i de anchet? rapid? . Dac? transportul este necesar autovehiculul la dealer sau magazin ?i au un tehnician profesionist -l ia pentru un test drive , ?n cazul ?n care este ?n stare de func?ionare , ?i v? va oferi o estimare ?n scris de repara?ii ?i r?spunde la orice ?ntreb?ri specifice pe care le ave?i cu privire la problema ta. Pentru mai multe informa?ii despre problema dvs. , v? rug?m s? vizita?i site-ul de mai jos . Mult noroc ?i au o zi frumoas? . https://www.tradebit.com/filesharing.php/search/0/2005+aprilia+leonardo+125
Jul 29, 2012 | 2005 Aprilia Leonardo 125
Buna ziua am si eu un tel nokia X3-02 si nu merge, cind bag o cartela in el imi spune (enter restriction code) ma-m tot uitat pe net si nu ii gasesc un cod de deblocare, tel la-m primit. este adus din...
Bun? ?nseamn? c? telefonul mobil este blocat la re?ea, ave?i posibilitatea s? debloca?i telefonul mobil prin coduri debloca .. mod sigur cea mai buna si de deblocare este de coduri debloca ?i cererea mea personal? este c? nu merg pentru programul de deblocare, deoarece, uneori, software-ul s-ar putea ob?ine corupt ?i poate datele dumneavoastr? vor fi pierdute din cauza c? ?i, de asemenea, dont du-te pentru deblocarea gratuit, deoarece codul generat de circula?ie pot merge gre?it uneori, sa-mi experien?? nepl?cut?, a?a c? am mers pentru deblocarea de codurile din superunlockcodes ?i unlocked.you pot ?ncerca prea dar se vedea ?n acest dac? ?ara dumneavoastr? ?i furnizorul este listat .. deoarece pentru unele servicii sunt disponibile numai coduri .. verifica cu faptul c? ?i ?n cazul ?n care furnizorul de ?ara dumneavoastr? este listat, apoi ob?ine coduri ?i de a debloca telefonul mobil ..
Sep 21, 2011 | NokiaFree Unlock Codes Calculator
Nu pot sa citesc email
Incearca prin alt browser. E posibil sa fie o problema de moment. Incearca totusi si aici:
http://mlogin.yahoo.com/w/login/user?_done=widget%3Aygo-mail%2Fhome.bp&.intl=us&.lang=en&_httpHost=us.m.yahoo.com
Da-mi un rate daca vrei si daca te-am ajutat. M-ar ajuta mult. Merci.
May 11, 2011 | Yahoo Messenger
Din greseala am introdus invers usb-ul in computer si hardul nu mai functioneaza.nu i-l mai vede in computer.in sistem i-l vede ca usb device.*** sa procedez ca sa-l computerul?cel putin sa pot sa-l...
regret dar nu prea mai ai ce face - cind ai introdus usb-ul invers s-a inversat si alimentarea lui asa ca aproape totul a fost prajit. daca ai noroc s-a prajit doar interfata carcasei - scoate hard discul din ea si pune-l intr-una noua
http://www.pcgarage.ro/rack-uri/filtre/general-tip-rack-extern-hdd-25-quot/general-interfata-hdd-sata/
si o sa fie ca nou.
Jan 21, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Cod de siguranta
Ce cod de siguranta frate ? Da si tu mai multe detalii daca vrei sa fi ajutat ! In al doilea rand daca ai blocat telefonul cu un cod de siguranta, nu il vei debloca decat la service GSM.
Nov 02, 2010 | Nokia 1680 Phone Unlocked FREE 1GB
8km raza emisie ? numai 1 real !!
pai 8 km bat in camp deschis. e si normal sa nu mearga intre blocuri.
Lucrez la cadastru si maxim in camp deschis am putut vorbi la 7 km fara probleme pana acum. In schimb le-am luat odata la munte si prin padure nu au ajuns la mai mult de 2 km. datorita obstacolelor. momentan o statie s-a stricat..imi tot apare ca receptioneaza ceva dar defapt nu receptioneaza nimic si nu pot primi nimic pe ea. in schimb de transmis transmite bine
Sep 16, 2009 | Uniden GMR648-2CK (22 Channels) 2-Way...
Keyboard problem for bogdan
pls type in english language
Jan 05, 2008 | Lenovo ThinkPad R51
Samsung Galaxy S Advance GT-i9070 Black 8GB Android 2.3 SIM Free / Unlocked Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
