Question about HP Laserjet M1522nf All-in-one Laser Printer
Supply memory error - HP Laserjet M1522nf All-in-one Laser Printer
  • HP Master
  • 783 Answers
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Posted on May 09, 2014
Supply memory error
remove the right hand side end cover ( formatter acces panel) remove the bad memory ( card about 1" by 3" )- if your not sure its failed try with new memory and see if error returns
Mar 04, 2014 | HP LaserJet M1522n MultiFunction Printer
Supply memory error
Remove cartridge, observe a small chip mounted on cartridge shell..This chip calculates the approximate toner levels, once its reached "Zero" printer says cartridge empty/low replace it.. If the memory is not detected due to any reason printer will say supply error or 10:xx supply error..
Replace this memory if available( locally its available ) or replace the cartridge.. Very few cases same error appears with faulty DC controller..
Ex supply memory:
Oct 28, 2013 | HP LaserJet P2055d Printer
10.00.00 supply memory error
Most of the laser toner cartridges comes along with the memory chip which helps to indicates the toner levels.. 10.00 supply memory error shows if memory fails/damaged/chip bad contacts/cartridge not seated properly..3_21_2013_5_19_03_pm.jpg
Mar 21, 2013 | HP LaserJet Office Equipment & Supplies
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
Hp laserjet P3005n gives memory test error when powereds
I am assuming that the printer is giving a supplies memory test error in which case it is a faulty micro chip on the toner cartridge. If this is the case then you need to replace the toner cartridge.
If the printer is not displaying supplies memory error, but actual memory test error then the problem is in the memory on the Formatter Board. The formatter board in these printers are prone to faults.
If your board has an added memory stick, I suggest that you remove it after turning off the printer and then power on again and see if the error is still displayed.
Jun 10, 2011 | Office Equipment & Supplies
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
I am getting 10.00.01 memory supply error on the cyan cartridge of my HP color laserjet 3500. The cartridge is nearly full and was working fine. I have tried cleaning the memory controller PCB contacts but...
I had a like problem and found that the chip on the cartridge was mounted without enough spacer such that contact was not being made with the memory controller PCB connector.  I cut some two-sided tape and put it behind the chip such that it stuck out further so that better contact could be made and the problem was solved.
Apr 28, 2009 | HP Color LaserJet 3500 Printer
Hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Apr 07, 2009 | HP LaserJet M1522n MultiFunction Printer
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
HP Laserjet M1522nf All-in-one Laser Printer Logo
294 people viewed this question
Seeker5211
Seeker5211
