Question about Garden pro Garden Sun Light GSL-S045 Hiking Gadget Solar Adventure Powered Flash
Solar lights not turning off - Garden pro Garden Sun Light GSL-S045 Hiking Gadget Solar Adventure Powered Flash
Solar lights won’t come on new umbrella. Turned the red switch on at the end of umbrella, and nothing.
Check first for any disconnect wiring --connect, 2nd test the actual light if its good or busted (defective)---change it same value. If its real new some Solar lights has a protective seal on its power sourse contact---remove it first.
May 08, 2018 | Solar Electrical Supplies
My solar panel is not working in my birdbath fountain. When I did a troubleshoot it said to test the unit with the fence unhooked. What is the fence?
Check the pump to see if there is a blockage stopping the impeller from moving. If you have a volt meter, measure the output of the solar cell in bright daylight to see if it is producing the correct voltage.
Jun 19, 2016 | Solar Electrical Supplies
How do i operate smart solar lights?
Place the solar panel in a sunny spot to charge the batteries. If the lights do not come on at night, the panel's light sensor may be seeing other light sources and needs to be moved. The light sensor looks like a small white circle with a wavy line across it. They are usually visible and located in the solar panel. Make sure it is in the dark at night, or it will not come on. You can cover the light sensor to test that the lights are working.
Jul 08, 2014 | Smart Solar Solar String Lights 20 LEDs...
Who first used solar energy?
Edmund Becquerel first hypothesized that light could be turned to energy in 1838, but the first solar powered motor was made by Auguste Mouchout in France a few decades later
Jan 15, 2013 | Renewable Energy
Solar Outdoor Lawn LIght Won't turn Off
photo cell is bad it detects when the sun goes down and connects the circuit
Jun 11, 2012 | Solar Home
I"m working on a project to create a solar powered
Hello. Think I found the necessary information you require. Check out this link:
http://www.solarpowerwindenergy.org/2009/04/26/how-to-build-a-small-solar-circuit-wiring-diagrams/
There are schematics for each stage.
This one is a ladder diagram schematic only:
http://electroschematics.com/5988/outdoor-garden-solar-lights-circuit/
Good luck, and if this helps, rate it a four-thumbs up please. Thank You.
Apr 21, 2011 | Atlantic Water Gardens SINGLE LARGE LED...
We bought a solar light a Westinghouse item # 37136608W It had a least 7 hrs of direct sunlight for over 7 hrs.but still does not work, We think we had it on. is it possible that the off switch shuts off...
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Mar 20, 2011 | Garden
Outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
Westinghouse Solar sensor issue
Put a small piece of black tape over half the sensor. This will make it more sensitive to light conditions.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 04, 2009 | Garden
Garden pro Garden Sun Light GSL-S045 Hiking Gadget Solar Adventure Powered Flash Logo
Top Garden pro Optics Experts
james laughton
james laughton
ray gallant
Are you a Garden pro Optic Expert? Answer questions, earn points and help others
