Question about GE Kitchen Appliances - Others
GE CK40B ELECTRIC FRYER OLD THERMOSTAT IS 4 CONNECTION NEW THERMOSTAT IS 2 CONNECTION
NEED TO KNOW IF WIRES ON OLD THERMOSTAT NEEDED ON NEW STAT NO WIRING DIAGRAM,
SOURCE: thermostat installation
how do I install a basic digital thermostat?
Posted on Feb 04, 2008
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
Posted on Jun 06, 2009
  • 128 Answers
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Posted on Aug 30, 2009
SOURCE: I need the heating element thermostat controller
Hi
I have come across a small business R.A. Colvin their knowlege of all heating products is second to none. if they don't they will find out. I came across their web sight by chance. www.racolvin.com.au
Posted on Apr 11, 2010
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
I have a Honeywell LR1620 Thermostat that I am replacing with a Honeywell RTH230B. I se where all the wires go to on the new thermostat EXCEPT the blue wire that is attached to the "W2" terminal...
If your old t-stat had a W2 terminal with a blue wire connected, and your new t-stat does not have a W2 terminal, then you may have purchased the wrong t-stat. The old is a 2 stage heat where your new is a 1 stage heat. 2 stage heat means the tstat will engage 2 heat elements, then if it continues to get cool inside, the Tatar will engage w2 and the remaining 1 or 2 heat elements. If you want it like it was to begin with, you'll need a 2 stage heat 1 stage cool tstat.
Oct 10, 2017 | Heating & Cooling
SWITCHING A DUO THERM THERMOSTAT TO A WHITE RODGERS 300 HEATING AND COOLING THE NEW ONE WE HAVE Y,W,B,RH,O,RC,G,A. TERMINALS OLD ONE HS, 7.5,COOL,FUR,HI FAN,FAN, GND,
FUR - OLD T'STAT - (W) NEW T'STAT
COOL- OLD T'STAT - (Y) NEW T'STAT
HI FAN - OLD T'STAT - (G) NEW T'STAT
7.5 - OLD T'STAT - (RC) ON NEW JUMPER WIRE - (RH)
need full model number of w/r thermostat for other wires
Jul 02, 2011 | Heating & Cooling
I am installing a new thermostat for my baseboard electric heat. The electric box has 2 wires comming into it. So I have 2 black, 2 white and 2 ground. The old thermostat had a place for all 4 wires (one...
One wire is "IN" the other is "OUT" A Thermostat works by "Breaking" the "Phase" line. It is just that simple. You usually have a pair of wires that connects, on the "Hot" side, to the always power ON line, & neutral. The Circuit, or Load, on the "Cold" side, has a a pair of contacts that open & close depending on Thermostat, in series with that conductor. Hot Contacts Cold P In-------------------><-----------------P Out
N----------------------------------------------------N
Mar 04, 2010 | Honeywell Programmable Thermostat Heater
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
How to change a thermostat on a pitco fryer
First off make sure you get the OEM pitco t-stat.
1. Unplug all power sources from the fryer.
2. Remove all oil or shortening from the fry pot.
3.Remove the sensing bulb from the brackets inside the fry pot.
4.There will be a double compression fitting entering the fry pot from inside the control area, remove both of these compression fittings.
5. Slide the sensing bulb and cap tube out of the opening in the fry pot.
6. Remove the mounting hardware holding the old t-stat to the cabinet
7.Disconnect the wires on the backside of the t-stat (Make sure to note the wire locations)
8.Connect the wires to the new t-stat.
9Repeat the order in reverse to reinstall the new t-stat
When you connect the larger compression fitting to the frypot make sure that you get a pipe sealant that is rated to 600 deg. F
any high heat pipe sealant for stainless steel should suffice for this.
Hope this helps You
Dont forget to rate me
Jul 07, 2008 | Pitco Frialator SG14 Deep Fryer
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Kitchen Appliances - Others Logo
41 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
