Question about Nexus NX Televison & Video
TV keeps turning itself off
TV will stay on for a minute or so, then turns itself off. I have to turn it back on.
    Top Expert:
  • Nexus Master
  • 74,198 Answers
Power supply regulator board [SMPS] fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 22, 2014
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
SOURCE: Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Posted on Jan 03, 2010
taran_2005
  • 10515 Answers
SOURCE: My P42 keeps turning itself
Disconnect the power supply for few minutes, say 30 minutes and then turn ON the TV.This would reset the TV. If you still see the same problem, it confirms a hardware failure.
As you could hear a clicking noise, it is more suggestive of a power supply problem. This a common problem on most of the Vizio's TV. You need to open the TV. Locate the power supply board. You would be able to find blown / bulged / leaked IC's. Take them out and re-solder the new one. ( you could get the caps from radio shack or even from fry's ).
I am pretty sure that it would solve the problem. If the problem still persists, revert and we could troubleshoot further.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 02, 2010
walesarumi
  • 6993 Answers
SOURCE: My philips flat screen 42PF55 tv keeps turning itself off. The gr
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Nov 12, 2011
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
Aug 15, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
Top Nexus Televison & Video Experts
Tom Chichester
Are you a Nexus Televison and Video Expert? Answer questions, earn points and help others
