Question about Gigabyte Atom Series Netbook: Q2005 - Intel« AtomO N570 1.6 Netbook
Fit new q2005 keyboard - Gigabyte Atom Series Netbook: Q2005 - Intel« AtomO N570 1.6 Netbook
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Try ebay for new keyboard just type in the model when you have it turn notebook over there should be one screw might have a small picture of a keyboard beside it if you,ve never did a repair like this try youtube for an instructional video if you can,t find one relating to your model don,t worry there pretty much all the same after the screw is out underneath turn notebook over now you need an opning pry tool to pop out the keyboard carefull not to bend it I normally start at the top and work your way along take your time when you get it nearly all loose don,t lift it right out its connected with a ribbon cable the clip either flips up to release it or pushes out not that much pressure so if your trying its not moving you could be lifting or pushing it the wrong way
Posted on Apr 23, 2014
Starts up. Password required but keyboard not typing correctly. Blue tooth keyboard not recognized.
The most likely cause is that the keyboard needs a new battery in it, inserted on the underside. After that it may be that the small keyboard comms dongle in a USB port is not making proper contact. Pull that out and insert it a few times.
Mar 26, 2016 | Tablets & eReaders
Why won't my table charge?
Will the charger fit any other device that you have? If so try to charge some other device. It appears that there are only two possible problems. 1 The charger is bad.- 2 The tablet is bad.
Read your manual regarding charging and how long the first charge should take.
Aug 15, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
New IVSO bluetooth keyboard - no instructions
How do I retrieve the password to complete the second part of pairing my keyboard!
Feb 02, 2014 | Dell Venue 8 Pro Tablet Computer
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
I have the leather case with the keyboard but cannot attach to the android table that was sent
well thats strange,, the tablet has 1 USB 2.0 port and the keyboard connects to that port as its standard.. Its a standard port so all usb 2.0 connects for it is standard.
http://www.amazon.com/Coby-MID7015-Android-Internet-Touchscreen/dp/B0047Q9GT4#productDetails
and
http://www.amazon.com/Tablet-Stand-USB-Keyboard-Carrying/dp/B004OB0EBQ/ref=pd_bxgy_pc_img_y
is what u have right ??? try turning the connector around.. It should fit.
Dec 30, 2012 | Tablets & eReaders
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Mar 07, 2011 | Acer TravelMate C110 Tablet PC
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Keyboard key popped off
The key should pop back on... if it doesn't then the brackets on the keyboard for that specific key are broken. The keyboard will still function properly... every key will work fine.
Or buy a new keyboard.. they are cheap.
Sep 08, 2009 | IBM Tablets & eReaders
Gigabyte Atom Series Netbook: Q2005 - Intel« AtomO N570 1.6 Netbook Logo
53 people viewed this question
Top Gigabyte Tablets & eReaders Experts
Are you a Gigabyte Tablet and eReader Expert? Answer questions, earn points and help others
