Question about Refrigerators
Lg lfx25950 light won't shut off
  • Refrigerators Master
  • 884 Answers
Sounds like the door switch is stuck closed. If you can pry it out (POWER OFF!), check if you have continuity between the two pins. If you have, even when you push in the lever, the switch needs replacing
Posted on Apr 22, 2014
How can I access the switch for the hi low off light?
The cabinet has to be removed, BUT removal exposes you to hazardous and potentially fatal voltages even with primary power disconnected.
Oct 22, 2015 | LG LMVM1935 Convection/Microwave Oven
Low flow water pressure LG model LFX25950
line to refrigerator not supplying enough water
if a saddle valve this is probably problem.
Aug 28, 2014 | Refrigerators
Lfx25950 Lg Refirgerator
sure can,, they have couplers called shark bites just get the correct size1/4, shut off water supply, cut the line and cram one of these in there http://www.sharkbiteplumbing.com/
Apr 07, 2014 | Refrigerators
Problem with LG LFX25950TT Refrigerator (Freezer portion)
It is likely to be either the circulation fan in the freezer or the defrost element. Check the fan is running( you can usually hear it stopping as you open the door, some still run) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer.
Jul 08, 2013 | LG LFX25950 Stainless Steel (247 cu ft)...
Error code if
IF is an error that states your icemaker fan is not running. You just need to order and replace the icemaker fan behind the back panel inside the freezer to fix the issue. Here is the part to order.
To replace the fan: Remove the freezer shelf. Remove the plastic guide for slides on left side by unscrewing phillips head screws. 2) Pull the grille forward and remove the grille. 3) Disconnect wire harness of the grille. 4) Remove the scroll assembly by loosening 2 screws. Replace the duct assembly.
Dec 01, 2012 | LG LFX25950 Stainless Steel (247 cu ft)...
Service manual LG french door refrig. LFX25950
at the front of the Ice Maker (IM) under the bottom the is a square button. push it. the IM should cycle. if it does not replace the IM
Sep 04, 2012 | Refrigerators
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
My lfx25950 is not making ice
Most likely your water control valve is defective on the side for the ice maker. There are times that there is a slow leak and water freezes in the fill tube that fills the ice maker. That can be fixed by defrosting the fill tube with a hair dryer until the water valve is replaced. The next like ly problem would be a defective ice maker and sometimes there are problems getting parts for the LG brand. Do this, fill the ice maker with tap water turn on and let freeze. If it drops the ice the ne dual water control valve needs replaced. If it does nothing then the ice maker is the problem. I will be back soon with part numbers and where to find the parts you need. Try the test and if I am helpful please rate my solution, Thanks, Sea breeze
Sep 02, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
