Question about Delphi 2001 - 2003 Saturn L200 Vehicle Control Module W0133-1865924
Turn signals wont work
When i signal either right or left flasher will rarely flash for a second or so, then stop. sometimes it doesnt even flash..i checked the fuses to hazard and signal and there both good. but the hazard rarely work
    Problem Solver:
  • 32 Answers
Have you checked the flasher unit itself its a large round or square block in your fuse panel
Posted on Apr 21, 2014
Testimonial: "yes and they seem to be fine"
How can I repair a malfunctioning left front signal light?
The flasher unit for the four ways is separate from the turn signal.
If the rear light is flashing fast means the front light is malfunctioning. Check all wiring from the dash to the light itself. I had one a wire was pinched and had broken
Jul 19, 2015 | Cars & Trucks
My right front turn signal on my 2001 ford ranger doesnt work and my inside right turn signal light on dash doesnt work and flashes really fast. Buld on right side was replaced and works when lights
was the correct bulb used? this sounds like a single function bulb was used NOT the bulb that will light with the headlights and ALso produce turn singles
Dec 06, 2014 | 2001 Ford Ranger Regular Cab
I trying to locate the turn signal flasher relay module
Makes no diff left or right turn, there's one flasher under the dash next to steering columb. Possibly in the fuse panel, but I don't think so. Turn the switch on and flip the signal, listen for the relay/flasher to be clicking. That's the easy way to find it. Even if all you can do is feel the unit flashing. Pull it down and change it. Just plugs into the accessory block.
Aug 26, 2014 | 2004 Kia Spectra
Turn signals and flashers
The flasher itself is toast. It’s mounted in the in cab fuse box. Looks like a small cylinder, usually silver metal or black plastic. Pop over to a parts store, usually about 5 bucks.
Dec 14, 2017 | Chevrolet Suburban Cars & Trucks
1997 Dodge Neon left signal lights work great. Right side blinks very fast.
Has the car been in a fender bender ? check for wiring going to the front and rear lights to see if on has rubbed into a ground wire or the body. ( even if there has been no accident.)
Apr 18, 2013 | 1997 Dodge Neon
Both fron turn signal flash when selecting a right or left turn, but rear lights work fine.
check the elements in the light bulbs sometimes they short together
Aug 23, 2012 | 1999 Chevrolet Lumina
Hey I own a 2005 sportster 883C. I have turn signal problem, thouhgt if anyone can help. When I turn the ignition on only the left side flashes, so I thought maybe its fuses. I checked...
although you can cancel the left turn signal there you could still have a faulty switch which is not turning on the right side signals
also have you checked to see if the bulbs are bad, as sometimes a short can blow both front and rear bulbs
Aug 04, 2011 | 1993 Harley Davidson XLH Sportster 883
LEFT TURN &4WAYS WORK NO RIGHT TURN SI98 BUICK PARK AVE
The first thing is to replace the flasher, the 4ways and signals use diffrent flashers, after replacing the flasher or changing it with the 4way flasher and see what happens. if this doesnt help then you may have a bad signal switch, a good trick is to turn on the signal and watch it as you move the lever around, pull back a little or lift it more and pull down a little, sometimes the switch contact goes bad and by moving the lever without take signal off will make it flash and if that happens then the signal switch is bad even if the 4ways work this still means a bad switch, the 4ways are wired through diffrent contacts then each signal, good luck.
Mar 17, 2011 | 1998 Buick Park Avenue
2001 Ford Ranger right turn signal doesn't work when the braking
Flasher Unit sounds bad... change the flasher, which is in the inboard fuse panel.
Feb 27, 2009 | 1986 Ford Ranger 2WD
Turn signals
replaced turn signal flashers and muti switch turn signal still won't work Why?
Nov 08, 2008 | 2000 Jeep Grand Cherokee
Delphi 2001 - 2003 Saturn L200 Vehicle Control Module W0133-1865924 Logo
Top Delphi GPS Experts
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
