Question about Briggs & Stratton Garden
Trying to crank mower, prime carb it runs long enough to burn that gas and dies? What should I do?
    New Friend:
  • 118 Answers
Your float is probably stuck. Look for the carbeurator that looks similar to this. Tap on the bowl on the bottom with the handle of a screwdriver and see if it runs...
trying to crank mower, prime carb it runs long eno - 4a01f893-9e03-49f6-a0f5-97a55466a5db.jpg
Posted on Apr 21, 2014
  • 376 Answers
SOURCE: My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
Posted on May 17, 2009
steve_lima
  • 181 Answers
SOURCE: I have a Brigs&Straton 6.5 Quantum lawnmower will not stay running. I can keep it running by restricting the amount of air entering the carb with my finger (choking it) The mower will start if it
the problem is in your carb.,at the bottem of the carb. there is a bolt that threads in to the carb.pinch off the fuel line so that no fuel comes out after the fuel bowl is off the mower.now look into the bolt that you took off.there should be a hole oppisit the head of the bolt.there are also two holes that go through the sides.these holes are the fuel intake to the carb,the hole in the center is the fuel nozzle.most likely you have dirt blocking this hole and not letting the motor get enough fuel to run.thake some carb cleaner and spray it in the hole.take an air hose then blow the nozzle out.while you have the screw out take the bowl off and check to see if there is any water or dirt in the bowl.after cleaning.reinstall the bowl and start mower again.should be running ok now.if not let me know and i'll guide you through another fix.let me know if this helped or not................
Posted on Jun 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Posted on May 15, 2010
SOURCE: lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
I am having trouble getting my trailcutter to stay cranked. It is not priming gas to the engine. I have replaced the fuel filter and fuel pump, and checked the hoses for any obstructions. Do you have
Try removing the anti backfire valve on the bottom of the carb and cleaning it. They sometimes stick closed due to ethanol gum. Mace sure you hear a click when you turn the switch on. The solenoid which operates the AB Valve could be bad or have a broken wire.
Sep 24, 2014 | Swisher 44-Inch 12.5 HP Trailcutter...
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Cant get my poulane pro 550 started
gas only lasts for 30 days in small engines try fresh gas if still have a problem take apart the carb and clean it out
Mar 24, 2012 | Garden
My Craftsman lawn mower has a problem. After starting, it only runs a few seconds, and then dies.
There are a few things you may want to try. One, the float in the carb may be stuck. Try putting a small amount of gas directly into the carb, this may free the float. Two, try replacing the fuel filter, it may be that some fuel is getting to the engine but not enough. Three check the air filter, same as with fuel the engine may be getting some air but not enough to continue to run. Hope this helps.
Jul 19, 2011 | Garden
TORO 6.5 RUNS FOR 4 SECONDS AFTER PRIMING THEN DIES.pUT IN NEW SPARK PLUG,new gas,but after priming run for several seconds.. it dies again....can you help...sounds like dirt in carb??/ It had run...
Did you check the filter? If the engine doesn't get air they it could cause it to die out like that. Also make sure that there isn't anything in the air line to the carb.
Did you check the gas line and make sure that you are getting enough fuel?
Jun 05, 2011 | Toro Lawn Mower With Toro Power Tools
Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Oct 07, 2009 | Garden
Starts when primed but dies...
check your gas cap, try running it without your gas cap on and see if that helps if so id either replace it or drill a really small hole in the top as modern engines the fuel is gravity fed into the carb
Jul 13, 2009 | Craftsman Garden
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mower won't stay running
Assuming it is a B+S engine, if it starts fine and runs rough and smokey as it gets warm and will not get enough speed, the problem is with the Diaphragm between the carb and fuel tank, it costs about £3 and is easy to fit if you have a 10mm and 13mm spanners and a cross heded screwdriver, ver annoying but relatively cheap and simple fix. Max.
Sep 07, 2008 | Poulan "Poulan" Push Mower
Garden Logo
24 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
