Question about Kenmore Elite 45986 Front Load Washer
What is fi dl error code - Kenmore Elite 45986 Front Load Washer
  • 6,784 Answers
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Posted on Jun 22, 2009
  • Michael Masters
    Michael Masters Jun 22, 2009
    If you are not experiencing any door lock issue and, the wires that connect the door lock mech to the Control are in good condition, this will confirm a control board error. replace the control in this case.
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Door is locked dL error code
DL error code means the door is locked. The door lock mechanism may need to be replaced. I would not recommend attempting this on your own I suggest you call a service tech.
Mar 17, 2010 | Kenmore Elite 45986 Front Load Washer
My front load locks and i get a error code fL 11 and dL
u need to change the main board. DL is a door lock error code
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
118 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
