Question about Whirlpool Refrigerators
Ice maker not working
There is no water in the maker but i do get water from the in door spout
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Look if the ice level lever is down (wire like lever)
Posted on Jun 08, 2014
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
  • 351 Answers
SOURCE: ice maker OK but water will not work? Whirlpool Estate TS25AF
hmmm, the only really way you will know if your water valve is working for the door is to jump it direct. unplug the machine get the valve out un do the line that goes to the door to the valve put a glass under the valve and jump it... if water then you have a door/control board issue.... no water than u need to replace water valve.
Posted on Apr 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
The water supply line to the ice maker on my Whirlpool side by side refrigerator is visibly frozen, and will not supply water to the ice maker. How do I fix this?
With the information given , I would say to pull fridge out from wall , and remove the 2 screws holding the spout . Pull the spout out and defrost with warm water . Reinstall the spout and replace the water inlet valve . Valve had to have a slow leak for the tube to freeze . A model number would have helped to give a more precise answer .
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker OK but water will not work? Whirlpool Estate TS25AF
Apr 26, 2009 | Refrigerators
No water at dispenser
apply hair drier to spout and surrounding area for a minute every ten minutes , after about an hour the ice that has formed will be loose enough for the water to come out of spout
Mar 28, 2009 | Hotpoint HSS25GFP Side by Side...
Water not getting to ice tray
Sherman usually (not always) the problem is a frozen delivery spout coming in back of the freezer. look where your ice maker and on the back wall and up behind that you will see the delivery spout area. The water valve may be bad or not opening also but it most likely has 2 solenoids 1 for water in the door and 1 for the ice maker. If you have checked and have the ability turn off the water and reverse the water inlet lines on the water valve. This is just to make sure the water passage is open. Hit the cold water cupplunger then look and see if you have water that cam into the ice maker if not your problem is in the valve or the line to the ice maker. Next hit the same plunger with the water line disconnected if you have water then your problem is in the freezer delivery and needs defrosting and cleaning if its a plastic spout it probably has lime covering it inside and freezes over or the water valve is leaking by a little and refreezing. with the water line off yuo will quickly know if its leaking by. and cover with a towel to prevent a mess if it sprays out when you try the plunger. If it still dosnt work try to check the coil on the water valve both coils should read about the same. If after all this works and you have water everyplace (thats why I said use the towel) the problem is in the ice maker circut. Either it is the main power, the ice maker motor its self, or or most likely its the fill valve switch.In any case if you purchase a new replacement Ice amker head all this will be new.OR Either replace the switch if it checks open or if its loose or there are broken parts. It requires a cam to open and close the switch so it only opens for about 5 to 15 seconds. .Hope this helps you let me know if I need to tell you more. Rate me accordingly please and Good luck.
Mar 12, 2009 | Refrigerators
My ice maker doesn't make ice but i have water in the door
Your machine has a dual water valve. The ice maker side coil is dead most likely. You can confirm this by loading your ice maker with a glass of water. If it chunks out a batch but fails to make anymore then that is a sure sign of a bad water valve solenoid.
Mar 08, 2009 | Refrigerators
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Water & ice
If it is both ice and water not operating then it could be the connector at the bottom of the door , the door light switch inside the freezer as this acts as an interlock or the micro switch that is operated when you insert your glass.
Aug 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side fridge / freezer - Icemaker problems
What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
24 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
