Samurai repair forum
I have an error code 160. Do you know what this could be?
  • steph
    steph Apr 21, 2014
    This is for a Bosch stove/oven. Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Po160 means --O2 sensor CKT No Activity (Bank 1 Sensor 20)
Posted on Apr 21, 2014
  • denis3002153
    denis3002153 Apr 21, 2014
    sorry i meant (Bank 1 sensor 2) not 20
  • denis3002153
    sorry i meant bank 1 sensor 2 not 20
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
Oct 19, 2015 | Washing Machines
How do i find the engine number of my suzuki samurai
this is easy, and i dont need to guess.
first off we, dont know what engine you have
G13?
G 16 what>? many sammi are swaps now, huge that is.
the FSM covers this. a free book,
here Ill post that. (why not post a photo of yours?)
25513060-xcqoluy0r3kgpc4qbsqstagz-4-0.jpg my G16 is here, very clear, outside USA< they dont have year code !
all this is reg. by law. of your country
that is the lower left mount bolt on bell housing, below master cylinder, G16T is 96' year T = 96
Mar 04, 2015 | 1994 Suzuki Samurai
Keeps giving me the F1 signal. Whats the deal?
Fellow, Academy of Sublime Masters of Appliantology
Joined: Sun Oct 7th, 2007 Location: South Carolina USA Posts: 6784 Flavorite Brew: waffle house coffee Status: Offlinespacer.gif F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Read more: Whirlpool Cabrio F1 code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/15527.html#ixzz1BPYo9agm
Get appliance parts at http://parts.fixitnow.com
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code F1 mean?
Hello there:
F1 = Pressure signal Out-of-Range -
fixes:
+Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
+If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, then unfortunatly you are going to have to replace machine/motor control.
Read more: Need help ASAP (Kenmore Oasis) - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/18981.html#ixzz1BErn5TM6
Jan 16, 2011 | Kenmore Oasis HE 27082 Top Load Washer
There is an error code of F 06 that comes up on the washer display. What does that mean?
Before changing components on this unit I like to remove and reinsert all wire connections at the board and motor. This tends to clean the small mount of corrosion that will build up on the connections. After you do this put the machine into a service cycle. The instructions on this is in the tech sheet ou found inside the unit. Part of the service cycle is running the motor at certain set speeds which checks the tach. Good Luck!
Read more: Whirlpool Duet F/06 error code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/10059.html#ixzz1BErA2200
Jan 16, 2011 | Maytag EPIC MFW9700S Front Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
