Question about Singer 4423 Sewing Machine
Singer 4411 needle bar height - Singer 4423 Sewing Machine
2 Suggested Answers
  • 1564 Answers
SOURCE: How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Posted on Aug 24, 2012
How to thread on a singer 4411. Thank you
To thread the upper thread, make sure that the needle bar is fully up, using the hand wheel. Put the thread spool on the spool pin and secure it with the spool holder. Use the end of the spool holder that is closest to the spool size. Bring the thread through first guide to the left of the spool holder. Slide it past and behind the guide before pulling it into the guide. Then bring the thread to the pre-tension spring. Similarly, the thread goes behind the spring and then comes forward. Next bring the thread down through the channel and up through the adjacent one further to the left. It helps to hold the thread between the spool and the thread guide. Once you bring the thread up through the second channel bring it from right to left through the slotted eye of the take-up lever. Bring the thread down and through the horizontal thread guide, the thin guide clamp needle and to the needle. Thread the needle from front to back.
The manuals for most Singer sewing machines are available from the manufacturer's site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4411 is http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf . See page page 16 (page 23 of the PDF) for pictures of the guides.
I hope this helps.
Jan 05, 2017 | Singer Sewing Machines
How do i adjust the needle bar on a singer 4411
I have repaired a few of these machines, and if yours is not stitching the problem is usually that the timing is off. Adjusting the needle bar is one way to get the needle eye and the hook timed but in this case it is not the answer. There is a timing belt that runs from the top to the bottom of the machine.and it has a tendency to jump a tooth putting the timing out. It takes quite a bit of work to get the machine apart, and some patience to get the timing back,
Sorry to say it's no easy fix.
Bob
May 28, 2016 | Singer 4411 Heavy Duty Sewing Machine
Singer 4411 will not pick up bobbin thread.
If what you say is the case, the needle/hook timing is off. You can search the internet for sites or videos showing how to do this yourself or take it for service.
May 21, 2016 | Singer Sewing Machines
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
How to oil a singer 4411 sewing machine
you oil it in the center of your bobbin case, also theres a small pad like thing just above your needle , there as well as inside your threading area where the spring is
Aug 13, 2014 | Singer 4411 Sewing Machine
Adjust timing
Presuming your needle is clamed in fully up position & is not needle bar height problem,this needle/hook timing should get your local sewing machine technician to get it adjusted correctly.
Oct 24, 2013 | SINGER 7470 Sewing Machine
I have a singer 4411 heavy duty and bobbin thread gets snagged
Either blunt needle or you may have a burr on the needle plate
Oct 06, 2013 | Singer 5417 Mechanical Sewing Machine
Aug 24, 2012 | Singer Sewing Machines
Singer 4423 Sewing Machine Logo
41 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
