Question about KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator
Kitchaid varies in temperature - KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator
  • 1 more comment
  • Tom Goodrich
    Tom Goodrich Apr 23, 2014
    I cleaned out the bottom section so yes it is clear. Temperature is set to factory defaults 38 refigerator and 0 for freezer.
  • Tom Goodrich
  • Tom Goodrich
    I am Starting to think it is has to do with the defrosting circuit.
  • 884 Answers
Check the condenser is clear and clean and the thermostat not set too cold
Posted on Apr 22, 2014
  • mike cooper Apr 24, 2014
    Is it automatic defrost? If so check the timed portion of the cycle and any thermistors attached to the evaporator
I just got a kitchAid standmixer today and I'm sooo happy,but when I turned it on i noticed a little spark going out from where i should change the speed ,, is that normal or do I have to return i
You are probably seeing some dust or the brushes wearing in, unless you smell something burning, its may be just breaking issues. Any electric motor will have small sparks at the brushes. Are they sort of behind the round brush replacement screws?
Jun 30, 2012 | KitchenAid Food Mixers
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Good luck and have fun. I hope this helps. Howard, Burke, VA
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Temperature varies over time. Cleaned coils.
During hot summer months and frequent openings this will happen - it is normal for temperatures to vary when you add in warm food or open the your refrigerator often and for a long time, if it is not your case, then the next thing I could think of is that cold air is escaping, you have a leak somewhere - check your door gaskets using the dollar bill trick - slide in a dollar bill in different areas of the gasket, shut the door, pull on the bill, if there is no resistence and the bill slides out easily, you have a gasket leak.
Aug 17, 2009 | KitchenAid Refrigerators
Suburban 2001 temperature gage fluxuating from high to low
Is it just the gauge or is the engine coolant temperature varying? Does the heater seem to vary in temperature when it is on.
It could be a couple of different things.
One could be a malfunctioning temp sending unit, it has lost its calibration.
Two, your thermostat is cycling open and closed from a weak return spring, worn out.
Make sure coolant level is correct and the mixture is 50/50.
Let me know.
Regards,
Apr 09, 2009 | 2001 Chevrolet Suburban
How do I replace the oven temperature sensor/thermal fuse in my Kitchaid oven?
Unplug the range.
Open the oven and look on the top left back wall of the oven to see the sensor protruding out. Unscrew the 2 screws holding the sensor and CAREFULLY pull it out.
Unplug the wire connector. Plug in the new sensor and CAREFULLY push the wires back inside.
Replace the screws.
Turn on the oven and bake me some cookies.
Apr 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator Logo
43 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
