Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Having the same propblem
I noticed one spot then two sports then ive then a hundered. I'm assuming in a couple of months I wont be able to see the screen
  • 4,234 Answers
Since this is a DLP set, try checking the surface of the lamp for any defects. Also, look into the lamp (when removed and cool) to see if there are any defects in the shiny coating down by the filament. If no to both, then there is some contamination or burning later on in the light path that should be examined by a service center.
Please keep us posted.
Dan
Posted on Jun 19, 2009
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
So I picked up a 2006 mini last year and I noticed in the last couple of months that the overflow tank goes empty every couple of days. I hadn't noticed anything on the ground until I had my oil...
Start on a day you're not using the car. park it in a spot where any fluid leaks will be imeadiately obvious and if you see a fluid leak jack the vehicle on the spot and get under it and start looking for wet spots. It could be something as simple as a bad or loose hose clamp.
Jun 24, 2011 | 2006 Mini Cooper
Won tturn on
Having received no response in over a month, I assume this is no longer a problem.
May 08, 2010 | Texas Instruments TI-83 Plus Calculator
Nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
Apr 16, 2010 | Nikon F3HP 35mm SLR Camera
Hi, I am having a problem with my home a/c. Ive been having to reset the high press. control reset button on the side of my outside condensor unit lately. Ive noticed that the fan is having difficulty...
If you spin the motor and it starts running, the capcitor is bad. Replace it and all should be well. High pressure is tripping as the fan motor is not starting when the unit comes on.
Aug 16, 2009 | Ruud Central System Air Conditioner
Kodak si xe
Of course it could be the batteries . check with Kodak on their website for tech support
Oct 17, 2017 | Cameras
Hopsean1
Are you using a Genuine Toyota replacement fuel pump? If not, get the Toyota part. "Aftermarket" pumps have been known to quit for no reason, I have observed this a few times.
Sep 22, 2008 | 2001 Toyota Sequoia
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
