Question about Kitchen Ranges
Error code 160 HD17282U/06 - Kitchen Ranges
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
You are being told the problem by the error code you will need the manual / instructions to find out what it is .
Posted on May 08, 2014
Error 06 code
Search for:
Make Model error code 06
Apr 28, 2017 | Singer Sewing Machines
OCE CM4010 L4-06 error
Hi Felix.
The link will take you to the answer and possible resolutions. Thread Sharp MX 3501N ERROR CODE L4 06
Aug 15, 2016 | Office Equipment & Supplies
F 06 error flashing
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
If you still get the error, replace the CCU.
Here is the part to order.
Nov 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Check the MCU
Nov 04, 2012 | Whirlpool Washing Machines
Ok.. I just purchased a 06 Dodge Magnum SXT from my brother w/ only 87,000 miles on it. But the problem is that the car barely turns over, and when it does it only runs for a few seconds and then stalls....
Start with a good battery. Then try starting it and let it run for a few minutes if it will. Then retrieve the error codes by first, shutting off all accesories, then turn the key to "on"- without starting it. then "off" then :"on": then "off" and then back to "on" and leave it so the OBD can read out the error codes in the odometer location. You should see 3 or 4 codes. Write them down and address them in that order. Sometimes repairing one item will correct multiple codes. Doing the key thing should take less than 5 seconds before it starts to display the codes. It will read "Done" when it reaches the end.
Oct 31, 2012 | Dodge Cars & Trucks
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
How to remove power stering light on 2008 volkswagen
Power Steering light coming on,it can be due to error code stored in ecu.The vehicle needs to be scanned.
For more help.Click the link below:----VW Jetta :Yellow Power Steering Light?
http://howtobyme.blogspot.in/2012/06/vw-jetta-yellow-power-steering-light.html
This will help.
thanks.
Jun 05, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Pejero engine turns over but wont fire check engine warning lamb stays on
For check engine light on,its definitely error code stored in the cars computer.,Getting the error code scanned by OBD 1 scan too, is advisable.
Also for car not starting issue,click the link below :----http://technoanswers.blogspot.com/2012/01/mitsubishi-pajero-turns-over-but-not.html
For check engine light coming on,click the links below :---
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
This will help.
Thanks.
Jan 27, 2012 | 1992 Mitsubishi Pajero
What is fault FO6
F/06 Washing Machine Error code -Motor tach Error code, control board not sensing motor. If error code appears in the high spin speed mode the door will be unlocked after three minutes.
-Check connections between washing machine motor and MCU (Motor Control Unit)
-Check wire connection on the MCU to the CCU (Central Control Unit) The CCU is on the top of the washer.
CHeck this video, as reference guide...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 17, 2011 | Washing Machines
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
