Question about Vehicle Parts & Accessories
2003 range rover has a vaccume leak - Vehicle Parts & Accessories
  • 194 Answers
A easy way to find a vacuum leak is to carefully spray carb cleaner on hoses and fittings when you find a leak the rpm will increase
Posted on Apr 22, 2014
How to reset air suspension in a 2003 range rover
This assumes the suspension has failed in some way. The cause could be a loose air line, a leaking air spring, the valve block, the compressor or the computer. Only a dealer or specialised LR shop can reset the computer, but you need to determine and fix the cause first
Jun 13, 2014 | 2003 Land Rover Range Rover
2003 range rover, vaccume line diagram
Vacuum diagram usually located on hood sticker
Apr 21, 2014 | Vehicle Parts & Accessories
Leaking coolant not overheating 2003
You are not filling it above the "full" mark, right ?
It has to have some space in the tank to allow hot coolant to expand.
Aug 23, 2012 | 2003 Land Rover Range Rover
Currently my 2003 Range Rover is displaying "air
Probably a leak in left front shock/spring. It's something a qualified tech needs to repair or diagnose. you don't won't to try that at home.
Feb 05, 2011 | 2003 Land Rover Range Rover
2003 range rover power door locks do not work
does the roof lamp work? if not then means your Vehicle in transport mode. to have it in normal mode you need to take it to a dealer or something equivalent to have the job done by approved diag. machine
May 19, 2010 | 2004 Land Rover Range Rover
I have a 2003 Range Rover HSE, am getting an ERROR CODE P0171 and P0174. What could this be and how can I fix it?
if its a code that is a lean mixture its probnably the intake gaskets or a vacuum leak.
Apr 30, 2010 | 2003 Land Rover Range Rover
I have trouble starting my 2002 Jeep Liberty plus I have error codes P0442 &P0455. What is wrong? and how can I fix.
PO442 & PO455 are for your evap system which has to do with monitoring your fuel tank and fuel vapor system this shouldn't affect starting at all.
Oct 11, 2009 | 2008 Land Rover Range Rover Sport
Range rover air suspension stoped working
Range rovers are notorious for air susp issues, over the years I have had several issues. Unfortunately a lot of the time even the dealers fix these by accident. Range Rovers.net is a good site for a lot of issues, that can be checked without testbook. To start check the easy stuff. If the car is a 2003-on the compressor is under spare tire, height sensors can fail and can be checked with a voltmeter, check all air lines and valves. Good luck
Jul 31, 2009 | 2003 Land Rover Range Rover
My 2003 Landrover will not go up or down.
you have a leaking front air spring and your abs is activating
Mar 31, 2009 | 2003 Land Rover Range Rover
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
