Question about RTO 50cc Moped Scooter
Baotian BT49 QT-9 wont start
I got it off e-bay started and ran for about 10 minutes,then stopped.will not start.
2 Suggested Answers
georgiejm201
  • 54 Answers
SOURCE: my treadmill runs for 15 minutes than stops for a
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Posted on Jan 12, 2011
Hi I have a Baotian 50cc bt49q 9r. Bike won't start I've cleaned the carb drained old fuel etc, bought a new battery and a new spark plug.CDI might be faulty which I have ordered or the coil pack ?
Hi, Neil and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
cranks but wont start
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
http://www.baotian-scooters.net/wp-content/uploads/2012/11/baotian-rocky-service-handleiding.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 01, 2016 | Motorcycles
Why does my baotian bt125t-12 evolution scooter cut out at 5000 rpm?
Hi, Darrell and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
Bike cutting out at Full Throttle 50cc Scooter
Troubleshooting
Baotian Classic Service And Repair Manual Part 1 of 2
Baotian Classic Service And Repair Manual Part 2 of 2
Baotian BT125T 12 Evolution 125cc
Baotian BT49QT 11 User Manual
Jun 16, 2017 | Motorcycles
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Turns over good but wont start, ran a little funny a couple of days ago . Today started and died , then ran all the way home ! Tonight went out to sart it , it didnt want to start then the 2nd time it...
Check for spark-if you have a tachometer, see if when you crank it the tach needle moves-if not, you probably need a crank sensor, which are not too expensive or difficult to replace.
Dec 26, 2010 | 1999 Dodge Durango
My 94 jeep cherokee started ran for a minute or 2 and stopped
i would suggest checking to see if you are getting fuel by disconnecting the fuel line at the fuel rail and turn key if no fuel then its either fuel pump or fuel filter. if you get fuel then it would be the spark
Jun 14, 2009 | 1994 Jeep Cherokee Country
RTO 50cc Moped Scooter Logo
32 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
