Question about Avanti 1.7 Cu. Ft. 4-Cycle Compact Top-Loading Washer
Water level sensor
The water never shuts off no matter what water level you choose.
    Problem Solver:
  • 10 Answers
Try pressure chamber
Posted on Apr 21, 2014
Water level
Need new vater level sensor switch
Dec 08, 2013 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
Mar 14, 2012 | Washing Machines
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
Our washer is not filling with enough water. We set it for a large load and the water level is that of a medium or maybe even less.
Hello there and thank you for choosing fixya
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 24, 2011 | Kenmore Washing Machines
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
Water keeps running after machine is full of water. it won't start the cycle no matter what load size you choose.
The water level sensor is either bad, or the air line going from the tub to the sensor has become disconnected or clogged, so that the machine never senses it is at the correct water level to start the cycle. Therefore it continues to fill. You will need to acsess this sensor by unplugging the washer and removing screws at back of control panel. Then lift the panel, remove clips to housing, and disconnect lid switch, then inspect the clear rubber air tube, if there is no noticable issuse, replace the sensor.
Nov 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
I have a 9 year old heavy duty top load washer that keeps overflowing no matter what water level it is on. I think it might need that part. If so how do I install it?
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Apr 01, 2009 | Frigidaire Washing Machines
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Maytag Performa water level
Jul 13, 2008 | Maytag Performa PAV2200
Avanti 1.7 Cu. Ft. 4-Cycle Compact Top-Loading Washer Logo
Top Avanti Washing Machines Experts
Jim Thurston
Kolbrun...
Keith Poitier
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
