Question about Hotpoint Dishwashers
Hotpoint dishwash not heating the water but it not the eliment
Hotpoint dishwasher FDW60G Aquarius not heating up, tried a new element but it not that and the old one has been tested and works, what next??
    Habit-Forming:
  • 119 Answers
Check and see if during the heating cycle there is voltage to the element. If not, you will need to replace the control board/module. from serial number 41011 part no is c00143209, to serial no 41011 part no is c00143207
Posted on Apr 21, 2014
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
  • 36 Answers
SOURCE: Hotpoint Aquarius DWF32 dishwasher pump replacing
its easy just uninstall the dishwasher and flip it on its back .i know it sucks but once the unit is out its no problem.
Posted on Jul 24, 2009
milten1
  • 1304 Answers
SOURCE: WATER NOT GETTING INTO DISHWASHER
itrs a real pain
but roll it out side
tilt it backward so your at 45 degrees
the dishrge hose is connected right to the pump
disconnect the hose and take a peek
Posted on Oct 08, 2009
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
  • 56 Answers
SOURCE: My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Posted on Feb 11, 2010
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Sep 08, 2010 | Hotpoint Dishwashers
Location of element
Hi, Hotpoint FDW60 got a concealled element.
You need to unplug and disconnect the dw, lay it flat on its back and remove the bottom tray (depending on the final letter for your model (FDW60G, FDW60P, FDW60T) you might need to remove the side panels and kickboard to release the bottom tray). Carefull with the floater switch. You should be able to locate the element straight away. Replace it and reverse the process.
Cheers
Feb 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint hda3700g00bb water not heating
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
e1
Jan 27, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius FDW 20. Not Heating
Yes take right hand side panel off, change heater from there.
Nov 02, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius dwf30 dishwasher
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
118 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
