Question about Pitco Frialator Kitchen Appliances - Others
Why won't the pilot valve turn on my pitco 35C+ frialtor?
I can push the pilot valve in but it won't turn any way. How can I get it to turn to the pilot or on position to light the pilot?
    New Friend:
  • 23 Answers
You turn the valve knob to "Pilot", push it in, and light it (use a long butane lighter-it's easiest) and keep the button pushed in for 20 seconds-1 minute. If the pilot stays lit, turn the dial to "On".
Posted on Apr 05, 2016
  • 5 Answers
SOURCE: pitco frialator
Is it doing more than lighting the pilot light? Or is the only action is the pilot light coming on, then off?
I would need to know more spacifically which model you had. Here is a list of manuals on the manufacturers web site so you can see for yourself.
http://www.pitco.com/doc_lib.htm
If I were to look at your unit, I would first look for, and see if there is a sensor (sometimes appears to resemble a piece of coat hanger sticking through some ceramic) that the flames will heat. The warming from the flames generates electricity. The electricity keeps the gas flowing. It is a safety device to keep your home/business from exploding from a build-up of unburnt gas.
Make sure the sensor is being hit by the flame. If it is, and the flame still goes out, then it just might be bad. I would imagine it would run about $20 for a replacement part.
if it works, great! If not, then you are only out $20.
Posted on Apr 27, 2008
kachbibi1
  • 979 Answers
SOURCE: Replace thermostats for Pitco 35c
Replacing the t'stat can be hard. I would first evaluate the cost of the vat. Do you have any leaks now in it? I would replace the t'stats. The cost is much less than the cost of even a used one.
Posted on Mar 03, 2009
kebah
  • 684 Answers
SOURCE: i have a pitco 35c
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Posted on Apr 07, 2011
kebah
  • 684 Answers
SOURCE: after changing the thermostat, the gas valve knob
Try to spray wd40 on knob.
If spraying wd40 doesn't work, you have to replace the gas valve.
Posted on Jun 08, 2011
  • 3239 Answers
SOURCE: Pilot won't light at all on Pitco Frialator.
Would not be a good plan to do this your self gas valve replacement is a gas fitters job
Posted on May 26, 2012
May 25, 2012 | Pitco Frialator 35CS Deep Fryer
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
My pitco frialator fryer's pilate wont stay lit
Check the thermopile, it should be free of soot or any form of dirt. Pilot flame quality must be good. Gas pressure should meet the requirement as stated on the nameplate.
Oct 22, 2010 | Pitco Frialator 35C Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
189 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
