Question about Blu Products Cell Phones
Open the back cover to install the battery - Blu Products Cell Phones
  • rogerf3
    rogerf3 Apr 22, 2014
    Hi Oladele Alatise, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? which phone is it ?
How to put battery in coolpad
most battery covers are a push down and back to open them
so put your thumb on the small indentation / bars , gently press down and back and the cover slides back and off
Dec 06, 2015 | Cell Phones
I JUST bought the coleman mini led headlamp and i don't know how the batteries are supposed to go in. the back will not open and there were NO instructions.
TO INSTALL OR REPLACE BATTERIES
1. Rotate body of headlamp until lights are pointing down and battery cover tab is to the front.
2. Insert edge of buckle on headband or a coin under tab and twist to unlock and remove battery cover.
3. Install 3 "AAA" cell batteries in the correct orientation as shown on the battery housing. Make certain all 3 batteries are installed
correctly.
4. Replace battery cover by first inserting the tabs on the back of the battery cover under the back edge of the battery housing, and
then rotate down until battery cover snaps into locked position.
For the manual: http://www.coleman.com/coleman/images/pdf/4343-704.pdf
Feb 21, 2011 | Coleman 3AAA LED Headlamp
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 10, 2010 | Sentry Fireproof Safe
I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
Locksmiths agree on How to install sentury safe batteries
Aug 07, 2010 | Sentry Fireproof Safe
I want to open the back cover, how do i change the nokia 6700 battery?
Push the back cover downward (towards the bottom), it'll open up..
You can refer to this tutorial.. Nokia 6700 simcard-battery installation
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | Nokia 6700 Classic Cell Phone
I have a Sentry OA5835. I am unable to open with factory combo and key. help
Sounds like the batteries are dead.
How to install sentry safe batteries
Mar 11, 2010 | Sentry Fireproof Safe
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
Mar 06, 2010 | Sentry Fireproof Safe
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
Aug 26, 2009 | Sentry Fireproof Safe
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Cell Phones Logo
18 people viewed this question
Top Blu Products Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Blu Products Cell Phone Expert? Answer questions, earn points and help others
