Kemore washer will not spin
My 4 year old front load washer will agitate, but will not spin or drain. Model # 417.44092500.
  • 109 Answers
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Posted on Jun 19, 2009
8 YEAR OLD LG FRONT LOAD WASHER WONT SPIN OR DRAIN
If the washer won't spin the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Aug 29, 2014 | LG WM1814CW Front Load Washer
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Broken Washer
sounds like you have a broken drive coupling....will the unit agitate ok??
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
