Question about Singer 7426 Mechanical Sewing Machine
Bobbin case loose - Singer 7426 Mechanical Sewing Machine
3 Suggested Answers
  • 51 Answers
SOURCE: Bobbin Case Comes Loose When Sewing
The plastic drop-in bobbin case, is the worst I have ever seen. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
Posted on Sep 06, 2009
SOURCE: my singer 327 bobbin case wobbley.
try changing the needle
the bobbin case may need to be replaced or the hook and hook
race may also need to be checked to see if there is something wrong
with them.
Posted on Nov 12, 2012
How to tighten a loose bobbin case on an Elna 21C sewing machine?
The only thing to really tighten on a bobbin case is the tension screw. (Unless, what is really loose is the mechanism--hook, shuttle--that the bobbin case fits into.) It will probably be worthwhile to just bite the bullet and buy a new bobbin case for the machine. They aren't that expensive and it certainly will relieve a lot of potential future frustration.
Jan 06, 2016 | Elna Sewing Machines
The upper thread breaks immediately I start operating
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw
to remove the old needle, place the new needle in the clamp with the flat
side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then
tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads
or lint
Apr 17, 2012 | Sewing Machines
Singer sewing machine bobbin thread knots rather than forming stitches or forms large loose stiches on bottom of fabric
What you have going on is a bobbin problem. The knots are referred to as birds' nests and happen when your bobbin thread gets caught on a piece of the bobbin casing. The large, loose stitches are normally caused by a problem with the bobbin case, a bobbin that is would properly, or when you're getting to the end of the bobbin's thread and the thread is loosely would on the bobbin at that point.
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
This should take care of the problem. If, for some reason it doesn't, you may well have a problem ALSO with your bobbin tension, and that should be looked at by a Singer Technician. You can find one in the yellow pages near you or probably by searching Yahoo Local. Happy Sewing.
Dec 08, 2010 | Singer CE-100 Futura Computerized Sewing...
Viking 1: where is the bobbin control, my bobbin is loose...
The bobbin spool is loose, the bobbin case is loose or the bobbin stitches are loose??????
If it is the last one - thread the machine with the presser foot up and see if this resolves the issue.
May 07, 2010 | Husqvarna Viking 1
Re-curring loose bobbin case
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Apr 24, 2010 | Singer 7442 Mechanical Sewing Machine
I have a 7570 and cannot get the tension the bottom thread is loose and can be pulled right thru I checked the top and adjusted the bottom and nothing seems to change.
When you thread your bobbin in the bobbin case, hold it only by the thread. If the bobbin and bobbin case fall, the tension is too loose. If this is the case, turn the bobbin tension screw 1/4 turn until the bobbin and bobbin case do not fall when only holding by the thread. The top tension should be set between 4 and 5. The best way to see which one needs to be adjusted is to do a zigzag. If the thread is pulling more on top and your top tension is set between 4 and 5, the bobbin tension is too loose. If your top tension is set between 4 and 5 and it's pulling on the bottom, the bottom is too tight.
Feb 17, 2010 | PfaFF Creative 7570
I have a Bernina Virtuosa 155 and use it daily. Without
In checking I can either adjust the tenion screw and if that does not work, purchase a new bobbin case.
Oct 27, 2009 | Bernina 1008
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Oct 04, 2008 | Bernina Artista 180
Threading bobbin
Put the bobbin in the bobbin case and slide the thread in the slot.
Pull the thread until it goes under the flat spring.
Now, by holding the bobbin case, pull the thread.
It should'nt be too loose or too tight.
to adjust the tension of the thread turn the small screw right for more tight, or left for more loose.
Hold the bobbin case upwards and put it in to the sewing hook until it clicks.
May 25, 2008 | Husqvarna Viking 1
Singer 7426 Mechanical Sewing Machine Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
