Question about Maytag M3DH30B2A Dehumidifier
Drain hose attachment
After not having used in 4 years, my dehu seems to be missing the attachment that the hose hooks to. There's the tube that goes into the tank, but seems like there was a hose nipple to attach to. I never used the tank.
SOURCE: Dehumidifier
Hey ya! To fix this u need to block that hose connection under the Dehumidifier. This will then re direct the flow to the Bucket collection mode. I have the same problem and resolved it this way after pullng mine apart. It looks like by default that hose connection at the bottom should have a plug/cap on it and after turning on ur dehumidifier this fills up then once full it starts to over flow into the bucket... Seems a strange design but thats how they have done it.
Hope this helps others.
Posted on Feb 23, 2009
SOURCE: do i need to disable the collection bucket to
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Posted on May 02, 2010
  • 4736 Answers
SOURCE: We had a hose attached to empty into a drain, but
Was the hose attached to the bucket or directly attached to the inside of the humidifier?
If it was to the bucket, the hose may have slightly pulled the bucket out of place, disengaging the safety switch. Unplug the unit and wait 5 minutes. Then plug the unit back in. Turn it to ON and remove the bucket and carefully reinstall it. You should hear a "click" sound when it's properly in place and the unit should start back up,
Hope this helps to solve your problem.
Posted on Mar 10, 2011
damneddle
  • 1607 Answers
SOURCE: I want to set up a drain hose from my Maytag
Yes, there is a knock out hole at the back of your unit. Refer to page 3 of this manual for the exact position:
http://www.appliancefactoryparts.com/content/pdfs/114658.pdf
Rate my answer if you find this helpful.
Thanks!
Posted on Sep 17, 2011
  • 4 Answers
SOURCE: i have the hose hooked up to the back but it keeps
You may not have the hose adapter installed properly. If it does not connect with the black drain pipe inside the unit, water will bypass the hose adapter and go into the bucket.
I own this dehumidifier. To connect it to a garden hose for drainage you first need the special connector pipe/adapter that comes with the unit. It's white plastic and about a foot long, It may be stored in the top of the bucket drawer, where it ships from the factory. Your hose connects to the threaded fitting on one end. The other end is inserted into the hole in the back of the unit. You slide it straight in until it mates with a drain connection inside the unit. You can see this black pipe connection if you pull the bucket drawer all the way out and look in the very top right hand corner of the opening of the unit. Once the white tube is fully and correctly inserted you'll find two plastic tabs on the tube near the hose connection. The larger tab points straight up and blocks the tube from being inserted too far. The smaller tab points down and hooks into the slot in the bottom of the round opening to keep it from getting knocked loose. Your dehumidifier should now drain through the hose instead of into the bucket. Of course, be sure your hose is routed across a floor to a drain or sump pump located lower than the unit, since the water flows by gravity.
Posted on May 04, 2013
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
Hooked up garden hose for continuous mode but it Problem with the Whirlpool AD35USS Dehumidifier Hooked up garden hose for continuous mode but it seems the water is going into the bucket and not through...
First, the hose should not exceed 5 feet in length. There is no pump in that model dehumidifier. It relies totally on gravity to drain through the hose.
If all of the above is as stated above, I suspect that hose or the tubing inside the hose connecting is clogged. Which forces the water into the bucket rather than the hose.
To remove the clog in the unit, you will need an 18" long plastic Zip Tie or something similar, that is appropriately sized to fit into the hose connection/drain hole. NO wire coat hangers though.
Carefully feed the Zip Tie in to the hose connection. About 6" in the tubing will bend. You need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of Zip Tie to work with. The slowly remove the Zip Tie while rotating it. This will breakup clog. As you near the end of the Zip Tie coming out, be prepared for some water to follow. DO NOT perform any of this while the unit is plugged in to the wall outlet.
Hope this helped you solve the problem, Robert. Please let me know. Thanks.
May 28, 2011 | Whirlpool AD35USS Dehumidifier
My frigidaire 70 pt dehu. has a continious drain hose but the bucket keeps filling up and shutting off. What can i do ? thanks for you help christian
make sure that the hose is not plugged and that it runs continuously flat or downhill... if it is trapped it will not drain...
heatman101
Apr 15, 2011 | Dehumidifiers
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
I have a GE Dehumidifier, Model # AHK40LKG1, Serial # AM166016. Thus far we have used the bucket to empty it. We now want to use the hose attachment to empty it. I find that I have the clear plastic tube...
I have same problem (ie, missing this drain nozzle). From my searching, the GE part number is : WK09X10006.
Found it on : http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
searching for 'drain nozzle'.
My searching (so far) is finding a couple places online to purchase this, but at $14-$15. Still looking for a better (ie, cheaper!) option.
Hope this helps.
Jul 25, 2008 | GE AHG40LJ Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
LG Dehumidifier overflows when attachment tube/hose attached
  • After 1 year of wondering why the LG instruction manual said no more than shove the white hose connector piece into the rear of the unit until secure, and relying on 'hit or miss' that the drain hose would actually work, (rather than filling up the bucket), I have finally found the solution. Ironically, it came while I was on my knees getting serial number from behind the bucket before they would try to help me by phone. There I saw it! The black interior drain piece inside the unit (top right when you remove the bucket) that the white house connector must be secured over. (Nothing in the manual ever told me to look for this.) As for securing the unit in the back--under the big vertical flap (which must point up and remain outside the unit), there is a smaller flap or triangular piece. They say that should be inside the unit, which it doesn't seem to go, because it is parallel to the large vertical flap), but if you push hard enough it does click onto the unit, while allowing the large while flap to remain outside (with the arrow pointing up), making the entire piece secure. Check once more to see if the white hose connector piece is secured over the interior drain piece (a black plastic elbow piece, on the top inside right where you remove the bucket, as I've said), and you'll be good to go! LG should be ashamed of their manual writing on this and the time I wasted getting my two units to work. However, at least these units are not fatally flawed as I was beginning to think.
May 19, 2008 | LG LD65EL Dehumidifier
Maytag M3DH30B2A Dehumidifier Logo
65 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
