Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Relief valve opens on my dyson dc24 when i use it with the canister on
My relief valve was opening up when I used my dyson dc24. I was able to take it apart and remove any blockages and I cleaned the filters. I turned it on to test if without the canister on and it worked fine. After I put the canister back on I had the same problem.
  • 2 more comments
  • Peter Hampton Apr 21, 2014
    it has a blocked cyclone assembly it needs to be taken apart and washed it has number 15 torx screws holdimg it together
    it is not that hard to take apart this section of the bin the other way is to was the cyclone section well with a garden hose then let sit in the sun for a few hours to dry,must be realy dry or you could burn out your motor.
  • Corky's Craft Shop
    Corky's Craft Shop Apr 22, 2014
    Christine, when you say cannister, you're referring to the dirt cannister correct? So, if you had a blockage with the cannister on the unit before and you're getting the same symptons now after having cleaned everything, all disassembled..........seems like there's only one thing to call it. It has to be in that bin. I've had a couple of them that died of other causes so I've kept the dirt bins from several and can test with them. It makes it real simple and easy for everything one to understand.
  • familyvac Apr 22, 2014
    It's still blocked somewhere. Check for more plugs, not on the tank.
  • Official Brand Answer
  • 2,572 Answers
Hi Christine, it's Jack at Dyson.
From your description it sounds as if the suction relief valve is activating because there may still be a blockage in the machine missed when you checked previously. There could also be an issue with the washable pre-filter housed within the cyclone pack.
For help locating the blockage, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
You may also want to wash the filters again, ensuring you follow the steps shown in the video attached. Use cold water without detergent, and allow both filters to dry completely for at least 24 hours before replacing them.
If you'd like further help or advice after you've given this a try, please contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on May 04, 2014
3 Suggested Answers
SOURCE: relief valve?
I had the same problem with my DC08. What I had found is that cleaning the main washable filter will remove the problem. I have a log fire at my place and I have found that the vacuum does not like the dust from the fire. Even though I sweep up any ash before vacuuming, the problem still exists. At times over winter I will have to clean the filter every week as it doesn't take long for the relief valve to start to open. Over summer, I have no relief valve problems at all. Hope this helps.
Posted on Jun 22, 2008
chrispurs1
  • 372 Answers
SOURCE: pressure relief valve opens
Hi.
If the hose works ok then you have A blockage in the section of the machine that goes from the brush roller to the wastebin.
Just remove the soleplate under the machine & check all the airways working back to the wastebin. definately check removeable inspection ports you will probably find omething in them blocking the airway.
http://dysonmanuals.llc.nu/
Posted on Jun 29, 2008
Can Dyson dc24 vacuum be used to extract air from vacuum storage bags.
Yes, any. Vacuum should be able to be used as long as the hose fits
Apr 05, 2015 | Dyson Vacuums
Vacuum relief valve
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC24 includes a suction relief valve. This helps protect the motor when too little airflow is passing through the vacuum. This could be due to a blockage, or because the two lifetime washable filters are overdue for wash.
To check for blockages, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24new/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc24
In normal use we recommend washing both filters at least once a month, using cold water without detergent. Allow at least 24 hours for both filters to dry completely before replacing them in the machine:.
I'm confident that washing both filters, and removing any blockages from the airways, will resolve the issue. However if you'd like any guidance from our experts after you've given this a try, you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 02, 2015 | Dyson DC24 All Floors Upright Cleaner...
Sucking and blowing sound went switched on
Hi Steve, it's Jack at Dyson.
From what you've described, it sounds as if the suction relief valve may be activating. This opens to let more airflow into the motor if the machine is used when blocked, or if the washable filters are very overdue for a clean.
In normal use, both filters should be washed using cold water without detergent, at least once a month. Allow at least 24 hours for both filters to dry completely before replacing them in the machine.
To check your DC24's cleaner head and airways for blockages, please follow each of the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24new/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc24
If you'd like some further advice from our experts after giving these checks a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 30, 2014 | Dyson DC24 Ball All-Floors Upright Vacuum...
Why does pressure release keeps going off in canister on dyson dc24 when turned on
Remove the filter in the ball and the filter in the hood. Turn on and if valve still pops off then you have a clogged hose or tube. If it's ok then one or both the filters are choked and require cleaning.
Jul 23, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
DC24 has an alternative suction when upright
Hi Claire, it's Jack at Dyson.
From what you've described, it sounds like the suction relief valve is activating - it opens to allow additional airflow into the machine when it's blocked, to prevent the machine from overheating.
You should be able to resolve this by checking for and removing any blockages, and washing both filters. You should find our online support guide useful when checking for blockages: http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use we recommend washing both filters at least once a month, as shown in the video attached. Use cold water without detergent, and allow at least 24 hours for the filters to dry completely before replacing them.
If you'd like some additional help after you've given this a try, please contact our experts at the Dyson Customer Helpline directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA)
Jan 13, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Rear canister valve
Hi there Coire, it's Jack at Dyson.
The valve you've described is the suction relief valve. This will open when something is restricting airflow through the vacuum cleaner.
In normal use, we recommend washing both filters at least once a month, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for both filters to dry completely somewhere warm before replacing them in the machine.
If you find this doesn't resolve the issue it's likely your machine has a blockage - to locate and remove this, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
For any further advice after you've given this a try, please contact our experts directly by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 09, 2013 | Dyson DC24 Animal Bagless Upright Vacuum
I have a DC24 dyson and it is not having suction without white button on canister pushed in.
I'm sorry to hear your DC24 doesn't seem to be working as well as it should be. The white button you've described is the suction relief valve - this helps protect the motor if the machine is used when blocked.
From what you've described, it does sound like your machine has a blockage - the filters may also need a wash if you haven't done this recently. Some quick troubleshooting checks should help locate the cause of the issue, and we'd appreciate the opportunity to provide further assistance by phone. You can reach our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack
http://www.dyson.com
Nov 19, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson DC24 makes a loud noise when turned on. The air flow seems to be going out another another end on the vaccum kind of by the on switch.
I'm sorry to hear you're having difficulty with your DC24. If the relief valve is activating, you may have a blockage somewhere in the machine, and the filters may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online Support guide:
In normal use, the filters need to be washed at least once a month, as shown in the video below. We'd recommend using cold water without detergent, and allowing at least 24 hours for the filters to dry completely before replacing them in the machine. It may help to leave the filters somewhere warm, such as beside a radiator, or in an airing cupboard.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
May 01, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
There is a - and i will call it - a relief valve on the top front of the canister that pops when the handle is released to vacuum - i have cleaned everything like the manual says but did not work -
Im not sure about this relief valve - if its a valve that has a flipable catch on the back of the handle its not always supposed to pop open. Perhaps you could be a bit clearer where the valve actually is? Older Dyson models have a valve on top of the handle where further small cleaning attachments can be fixed onto clean. If its clogged then a wire brush will need to be inserted into the handle to clear the clog thus making the attachments **** up dirt.
Mar 24, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Relief valve?
Mar 09, 2008 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
146 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
