Question about GPX ML648B MP3 Player
I dropped it and it will not come on - GPX ML648B MP3 Player
    New Friend:
    Problem Solver:
  • 9 Answers
She broken mate
Posted on Apr 24, 2014
I have a voltage drop when my fan comes on or if I use my lights. When not usi g them my voltage is around 13.2 when they are on it drops to 11.5 or lower
The battery is fubar. You will always have a voltage drop when the battery is being used. But the drop you are experiencing is caused by the fact that the battery is weak and cannot work up to potential. That is why you have the drastic voltage drop and the quick depletion of charge.
Replace battery!
Jun 12, 2016 | ATVs
Tip
Excel - Drop Down List Ever wish that you didn't have to type...
Ever wish that you didn't have to type out the same thing over and over again? Well you can save time by using Excel's drop down list!
Drop Down Preparation
Imagine that we are creating an Excel spreadsheet to document our purchases from the grocery store. For each purchase we want to mark down the name of the food and the type of the food.
The way a drop down list works in Excel is that it takes values from some place on your spreadsheet and uses them to populate the options in the list. Lucky for us, the type of food is a perfect opportunity to use a drop down list!
In cells A1 through A7 enter the type of food that will be used for the drop down list.
Creating a Drop Down List
Now that we have a source for our drop down list, we can create a begin to create our drop down.
1. Select cells D2 though D20 (We will be creating a drown down list for each cell in this range)
2. Click the Data menu and select Validation
3. Choose List from the Allow drop down menu
4. Click the Source button that appears to the right of the textfield
5. Select our source cells A1 though A7
6. Press Enter and Click OK
Testing Your Drop Down
All of your cells in the Type column should now have a drop down list. To test to see if your drop down works, click on cell D2 and then click on the downward facing arrow and see if all the types of food are available.
on Nov 19, 2013 | Microsoft Excel Computers & Internet
How to adjust rifle scope
You need to sight in the scope and rifle to 100 yards then reset the dial making sure the knob as the manual says
do a check sight in
Then you turn on the electronics
the drop number you input is 112 and the BC is 55
as you haven't given an altitude for sight in or shoot site I have allowed for them being equal
you now shoot at a target at 400 yards and for each inch below or above the aim point add or subtract 6 from the drop number
drop number entered is 112 and your shot is 4 inches low
4x6=24 so your new drop number is 136
and if 4 inches high the drop number is 4x-6=-24 new drop number 88 so you now change the inputted drop number to the ones you have and shoot a few groups at 400 to confirm point of impact and aim point and adjust accordingly
Forgot to explain that the 112 drop number is the calculated drop for your round at 750 yards and that you are changing it by confirming the actual drop at 400 and the scope is calculating internally for 750
Apr 10, 2017 | Burris Optics
Ref. Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid....
Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid. On other monitors I have used the drop is much slowe
Jun 24, 2010 | Health & Beauty
What is a drop in bobbin?
You can see examples here -http://www.singerco.com/resources/operation_basics.html
The top load is the drop-in.
The shuttle on the machine with a drop-in collects lint and needs more frequent cleaning.
I find the rotary (front or side load) more stable and the shuttle requires less cleaning.
May 11, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Mr.
The number of drops will depend on the liquid (because different liquids form different size drops), but here's the simple solution. 1 US teaspon is 4.93 milliliters. Count the drops it takes to fill a teaspoon. If that's not precise enough, you can multiply the number of drops by 1.0146 to bring it up to 5 ml.
Jan 04, 2010 | Measuring Tools & Sensors
I want to block drop detector in hp plotter 1050c plus
If you are running the Drop Detector Test then all you have to do is open the Window and insert a thin piece of paper inside the Drop Detector in order to block it.
If you want to disable the Drop detector altogether than you can simply unplug the drop detector. This will result in a system error 0C0030 Bad Drop Detector.
WARNING Switch off the printer and remove the power cord.
1. Remove the Printhead Cleaners (Refer to the User Guide).
2. Remove the following
  1. Right Hand Cover
  2. Service Station Assembly
3. Disconnect the Drop Detector cable from the Service Station Cable.
4. Remove the screw (item 1) that attaches the Drop Detector
Assembly (item 2) to the Service Station (item 3).
5. Remove the Drop Detector from the Service Station
Sep 21, 2009 | HP DesignJet 1050c plus InkJet Printer
Ice will no longer drop to ice tray
You havge a bad mold heater in the ice maker.
May 04, 2009 | Sub-Zero 642
GPX ML648B  MP3 Player Logo
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
