Question about Arris DCT6200 DTV Receiver
Motorola DCH4616 pinging sound
Certain channels emit "pinging" sound
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
High ping wifi
Contact Motorola Solutions Get Support or Zebra Support Downloads
Mark
Motorola Support
Apr 15, 2014 | Motorola MC9190-G Handheld Mobile Computer
Radio beeps after you release push to talk
Might be a low battery warning. Try swapping battery.
Mar 20, 2014 | Motorola CLS 1410 (4 Channels) 2-Way Radio
One of my Motorola HT750 radios makes a constant BEEP tone on all 4 channels. Worked the last time I used it with no issues. Took it to get reprogrammed and all of the setup/frequencies were fine. Could...
Typically any unprogrammed channels when selected will emit a long continuous beep. It is possible your radio has a programming problem, or a channel select problem, or another internal problem in need of repair.
Best regards.
Oct 01, 2013 | Radio Communications
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Motorola mtx 8000 radio
Yes. That is a strong possiblity. Many models of Motorola will emit a tone when not programmed, or by placing the channel selector on an unprogrammed channel.
Aug 21, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Change scanning feature for different channels
When having the radio programmed indicate to the programmer which channels you would like to have in a specific scan group. They an at that time set up a particular group for you.
Mar 13, 2008 | Motorola Radio Communications
Arris DCT6200 DTV Receiver Logo
42 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
