Question about Seagate Televison & Video
Please, what is the meaning of "excluded files" on the Seagate Media Sync application? And how do I overcome this problem, that from 124GB sync 34GB are excluded?
Sync from MacBookPro to Seagate Wireless 1TB with USB port
  • Heinz Hofstetter
    Heinz Hofstetter Apr 23, 2014
    It excludes obviously some files by the sync transfer. (For example with the app "SyncTwoFolders" and the same medias and files, the problem does not exist - it transfers all files.
quare3
  • 48 Answers
SOURCE: Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: File Format not supported
You have to be sure that the files are all mp3 files, or wma (windows media audio). Check the rip settings in Windows Media Player. If you rip CD's in a format other than mp3 or wma you will not be able to sync the files to your player. I would suggest sticking with mp3 - as mp3 files are compatible with any player, including ipods.
Posted on May 06, 2009
  • 10 Answers
SOURCE: i cant sync my madcatz ps3 wireless controller
try to plug it in and then press the ps button or let it sit for a little bit while plugged in and then try it
Posted on May 27, 2009
christykraj
  • 107 Answers
SOURCE: why does my omega media player go out of sync 75%
Try to reset the drive to the factory setting and see whether it helps.
This can be done by Set Up >> Preferences >> Defaults >> Reset.
Good Luck!
Posted on Sep 07, 2009
Thompsons196
  • 350 Answers
SOURCE: my windows media player won't sync with my mp3 player
Go to Run enter regsvr32 wmp.dll RUN AS ADMINISTRATOR if needed if the problem is there it should fix it.
Posted on Jan 27, 2011
Fn device cannot restore or sync properly.
restore ur device via itunes and then do it ... upgrade to the latest firmware as well
Jan 12, 2010 | Apple iPod nano
Nothing except songs will download. How do I put movies on? Who designed these retched things? I have tried a fox digital copy that is suppose to work but still nothing. (Ice Age 3) Please help me before I...
Convert files to WMV so they work with your MixMax you can download the Magic DVDRipper found at www.magicdvdripper.com. You can run the trial 5 times so I suggest before shutting out the program to do all the movies you can. When you do it, under the output folder click on Profile and click more profiles. There will be a Disney MixMax option choose that one, rename your title and pick your destination folder and then click start it will do the rest. When finished just copy and past the movie to either your player or to a SD card. Good Luck, I hope this helped. Please rate me, Thank you.
Dec 13, 2009 | Disney Mix Max Digital Media Player
Seagate freeagent go status icon stays red what is the problem?
When a backup or sync has failed, the red icon continues to display until the next successful backup or sync. You can view the log file to determine why the backup failed.
Nov 11, 2009 | Seagate FreeAgent Pro 500GB External USB...
How to sync .ipa files from computer to ipod?
iPod as in touch? If so then you just select the sync applications option in the tabs in iTunes. If you mean a 'standard' iPod then the applications aren't compatible so won't function - if you just want to transport them you need to enable disk use (disable automatic syncing within preferences, deselect 'sync when connected' and select 'manually manage music & videos' in iTunes, then under the music tab you can enable disk use. Your iPod will then appear as a hard drive and you can drag and drop your files onto it.
Oct 28, 2009 | Apple iPhone Smartphone
HELP!! I'm 60 yrs old and not a computer/electronic wiz by any means. How do I download a cd on to my Polariod media player (MPA-20011). My computer has Windows XP and if possible please take mr thru it...
  1. Save the files from the CD to your computer.
  2. Connect your player to the computer, a dialog box will appear asking you what do you want windows to do.
  3. Select “Synchronize media files” and click OK.
  4. Drag and paste the media files from “My Computer” folder to the sync list of windows media player.
  5. Select “Start Sync” on Windows Media Player to start file synchronization to your player.
  6. When the synchronization is complete, you can disconnect your player.moz-screenshot-1.pngmoz-screenshot.png
Oct 20, 2009 | Polaroid PDM-0721 Player
Won't sync
Are you using vista? you may need to uninstall that application that syncs and reinstall it. Usually this happens when he original source file that it wants to save to is changed.
Jun 22, 2009 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Apr 06, 2009 | Philips GoGear SA3245/37 Digital Media...
Ipod touch applications wont install
Please connect the cable of the ipod to the PC, then it automatically you will see the sync tab.
Jan 06, 2009 | Apple iPod touch
Mp3 player keeps getting SYNC notice
For NS-DA1G and NS-DA2G: If you are receiving a SYNC notice, your DRM media license has expired. If you are using a media manager like Best Buy Digital Media Store or Windows Media Player. you will first need to authorize the player as an MTP device (device authorized to play Digital Rights Management song files) and then re-acquire the licenses for the tracks. There should be a button that allows this function in your media software.
If you want to remove your DRM tracks, got to:
MENU - Settings - USB - File & Folder
This puts your player into Mass Storage Mode. Once in this mode the player will act like a USB drive and you can navigate to and delete your unwanted files.
Dec 04, 2007 | Insignia NS-DA1G MP3 Player
Televison & Video Logo
35 people viewed this question
Top Seagate Televison & Video Experts
Are you a Seagate Televison and Video Expert? Answer questions, earn points and help others
