Question about HP Officejet Pro X476dw Wireless Multifunction Inkjet Printer, Copy/Fax/Print/Scan
Copy or scan
My new HPPro will not copy or scan it just sits in an ideal mode when copy command given. Same with scan. What can I do to resolve this?
2 Suggested Answers
sonu_sehgal
  • 421 Answers
SOURCE: hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Posted on Jun 03, 2009
How to fix hp laptops
Step one: Turn your computer on, booting from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc. Remember, you may need to change the boot order inside your BIOS to have the your DVD drive boot first.
Step two: After the installation or recovery disc loads, if prompted, select your language settings and then continue. If you are using the installation DVD, when prompted by the following screen select Repair your computer.
Step three: The computer will take a moment now to scan itself for any Windows installations, after which you will likely be given a choice to select which installation you wish to repair. Select the appropriate Windows installation from the list and then continue. If by chance a problem is detected in one of your Windows installations at this initial stage, the system may also ask you if it can try to repair the problem automatically. It is up to you if you wish to let the system try to repair itself, but otherwise just select No.
Step four: Once you have reached the System Recovery Options screen, as shown below, you will be faced with a list of choices that can aid you in repairing a damaged Windows 7 operating system. If you wish to try the Startup Repair option first, it is often successful in automatically fixing many different start up issues, but in this article we will be using the Command Prompt option to resolve our problems manually. So, click Command Prompt to continue.
Step five: Now sitting at the command prompt, enter the following command and then press enter:
The above command will scan all your disks for other operating systems compatible with Windows 7 and allow you to add them to your system's boot list. If this fails, you may need to backup the old BCD folder* and create a new one in its place with the following commands:
bootrec.exe /RebuildBcd
Aug 12, 2014 | HP Computers & Internet
HP Pavilion A6700y system restore with disks doesn't work
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Aug 05, 2012 | HP Pavilion a6700y PC Desktop
How to resolve error 5 in printer canon pixma mp198
Please follow the below mentioned steps to Reset Canon Pixma MPC190 Printers.
1.Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2.Choose TEST MODE.
3.Select 8 PRINTER TEST TEST MODE.
4.Choose 3, EEPROM CLEAR
5.Select 0, INK COUNT
6.Press the Set button.
7.Click Stop / Reset button (return to item 3), and again press the ON / OFF
This should resolve the problem. For any further assistance please reply back.
Apr 17, 2011 | Office Equipment & Supplies
How to give command to check virus
You have to open your anti-virus software, whatever you have installed on your system, and run a scan of the computer. (Go to STart>All Programs>choose your AV or internet security suite>Computer Scan). The AV program is not a part of windows, so each one has a slightly different user interface, but what you want is to do a complete or in-depth scan.
If you suspect you have a problem with malware, I recommend you follow at least the first four steps of this malware removal guide.
Using MBAM to scan your system will often detect and remove problems your AV may have missed. It is one of the front-line tools in the parasite fight, used by experts and novices alike.
If you have any trouble, write back with the details and we'll be happy to walk you through it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 10, 2009 | Microsoft Windows Vista Ultimate Edition
My Dell All-in-One 924 Printer stays in copy mode
hi  s_witt212  :
u can rest assure ., cause the default mode onthe printer is : mode -copy .
all dell ink jet printer model s have that as the default option .
the other modes are mode scan and mode fax .
u can choose any mode based on ur need .
hav a gooday !
Jul 25, 2009 | Dell 924 All-in-One InkJet Printer
Hp 1400 does not print from print command by computer
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
I install brico pack(themes or xp) after some days i download servicepack 3 from internet and istall that to my pc. install sucessfully, but after restart windows diint get in i just see black screen ony.....
Follow the steps given below to resolve the issue.
1. F8 at system startup.
2. Boot to safe mode with command prompt.
3. Perform a system restore.
For instructions on how to perform a system restore from Safe Mode with Command Prompt use the link given below: http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
If this fails do a system restore from Recovery console.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
I have a canon mp460 printer that i have just re'filled and i am still gettin the 'ink running low' message on screen. how do i resolve this problem?
On the maintanance screen is there a "Ink counter Rest" tab. It must be clicked on as soon as you put the cart back in.
I also got the following from a website out there:
1) Enter SERVICE MODE by pressing sequentially Menu Copy Scan Copy Copy or Menu Copy Copy Copy Scan (on some models)
2) Select TEST MODE.
3) Press ‘+’ 8 times till ‘Select [8]’ PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Hope that fixes it for Ya...
Geno
Mar 27, 2008 | Computers & Internet
Scanner not working
I understand that you are unable to scan after upgrading the compuer from ME to XP.
Please follow the below given instructions to resolve the issue.
Check for the communication between the computer and the printer as scanning needs bidirectional communication unlike printing.
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are unable to scan using WIA, confirms that the issue is with USB drivers, please follow the below given instructions to refresh USB drivers:
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key, this will display the Windows Startup menu.
4. Select Safe mode.
5. After Windows loads in Safe mode, right-click the My Computer icon and select Properties.
6. Select the Hardware tab and click the Device Manager button.
7. In the Device Manager Window, double-click the Universal Serial Bus controllers.
8. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
9. Click OK to confirm the removal of the device.
NOTE: Repeat steps 8 and 9 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled.
Now, restart the system. The system automatically detects and reinstalls the USB port.
Then try scanning from WIA and if that works try scanning from HP Director.
Please click on Start>>Programs>>HP>>HP Director.
If unable to scan from HP Director, search for the file " hpqscnvw " in C Drive which is the executable file for Scanning.
Double click on My Computer to open it > C Drive > Programs files > HP or Hewlett Packard > Digital Imaging > Bin Folder. Check for the file " hpqscnvw " there.
If found double click on the file to and try scanning. You can also save the short cut of the file to desktop and can use that file for scanning.
Run the scan diagnostic utility to resolve the issue.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=oj-45265-1
ScanDiagnosticUtility_ver_1.5.exe
Just copy and paste the entire link into the Internet browser's address bar and press enter
If you are able to scan from computer, then follow the instructions from the below given article to scan from the printer front panel.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00503569&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Jan 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet Pro X476dw Wireless Multifunction Inkjet Printer, Copy/Fax/Print/Scan Logo
15 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
