Question about Recaro Milano Group 2,3 Car Seat Silver
Torn base material
Because of bad road we have driven on, the base material of our seats is torn and the seats have sagged.
  • Recaro Master
  • 1,629 Answers
Hi Pieter
We'd recommend you contact Recaro direct
Posted on Jun 22, 2014
After starting brakes don't let the car move on- they stay on. Why?
This has been an ongoing problem since brake friction material stopped being asbestos based. Some none-asbestos compounds are very porous and can contain a quantity of different metals.
The problem of a sticking parking brake can be a mechanical linkage or cable type problem or the friction material welding itself to the brake disc or drum or a combination of both. This tends to be a particular problem on vehicles where the usage rarely or never get the brakes thoroughly hot.
Brakes are open to the atmosphere and can become saturated with dew or condensation.
One customer experienced the problem so severely he had to apply a lot of power to get moving at all. The car started with a tremendous bang as the friction material was torn from the disc pad backing. Later I needed to use a hammer and chisel to clean the disc.
Fitting only OE friction material might help and not using the parking brake overnight...
Jan 21, 2016 | Cars & Trucks
How do you dissamble the drivers seat to access the heating elements to repair them
There 4 bolts that hold the seat track to floor board. remove seat turn over and you can see the bolts that hold the track on remove them. now follow the material down to seat base this is a plastic roll over clip they should pull straight out remove cover to access heat element reassemble.
Nov 11, 2013 | 2003 Pontiac Bonneville
How to replace seat in jetta beepa walker
Contact Jett's beeper manufacturers customer enquiries, they should be able to tell you who your local spare parts distributors are. I have changed similar material seats before and they usually just clip into place on the underside of the frame.Its a simple job
Aug 07, 2013 | Baby Gear
I would like to reupholster the front seats but they have side airbags. Can I do this?
Manufacturer recommends that you do not, it may change the way the air bags are deployed, even if the seat is torn in that area on the seam they do not recommend evening stitching the upholstery. only replace with factory materials.
Oct 17, 2010 | 2001 Pontiac Aztek
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
I hear the front suspension rattle when i go over pot holes or cracks in the road. At first it was just the drivers side now i can hear it on both sides. What could this be?
could be ball joints, bad shocks, loose brake calipers or a broken coil spring although the last one would also show some sagging of the suspension.
I suspect it 's balljoints.
Aug 06, 2009 | 2003 Toyota 4Runner
How to fix a drive axle assblemy
tommyscott: you are wanting to know how to fix a drive axle assembly? These parts have become so cheap to buy remanufactured, that it is not economical to rebuild them your self any more. I don't know of any shops that actually rebuild drive axles any more. I may occasionally replace a boot if one has been recently torn, but if the car has been driven for a while to where the CV joint has been exposed to road grit and foreign matter, I replace the whole axle, it's cheaper!
Jul 17, 2009 | 1997 Chrysler Sebring
Cannot remove Licence plate light Bulb
Sometimes winter road salt will cause these lights to do what you found. Try moving the bulb from side to side as you push it in. What you are trying to do is brake the bond created by the over heat or corrosion. If the bulb brakes, a real possablity, just get a good size stright screw drive and with the power off insert it into the base an tap it with a hammer, don't drive it home just into the base material so as to get a grip. The tapping will seat the screwdrive head and also brake lose the base. Mind you the holder may have seen better days and need replacing. They are avalable at any auto supply store. Good luck.
May 11, 2009 | 2006 Hyundai Azera
1990 gmc vandura. need to remove armrest from front seats
some are and some are not .call a big junk yard and ask them what the inner change is.
Mar 22, 2009 | 1990 GMC C2500
Sagging ceiling on toyota camry
You can't glue that old headliner material onto the old rotted foam that came off the material anyway or your gonna have a real clumpy mess on your hands. Buy new material at a material shop like Hancocks fabric and put new material. Its to cheap to do it half ......
Greg
Dec 03, 2008 | 2000 Toyota Camry
Recaro Milano Group 2,3 Car Seat Silver Logo
53 people viewed this question
Top Recaro Baby Gear Experts
Dorel UK
Dorel UK
Are you a Recaro Baby Gear Expert? Answer questions, earn points and help others
