Question about Kyocera Office Equipment & Supplies
C2126 grinding noise when printing
Grinding noise when printing. The cartridges have been in a while. I am also having problems getting cartridge to fit. I have to angle them to get in
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
  • 9 Answers
SOURCE: HP Deskjet 6980
Take a look to see if the printer Cartridge Carriage belt is hung up
or something else is jambed.
Posted on Apr 25, 2008
SOURCE: printer cartridge moves but does not print
i change the cartiage but i can not print or copy?
Posted on May 17, 2008
SOURCE: Print Cartridge Problem- HP PSC 1513
My print cartridge problem was finaly solved by replacing the power supply cord!!!
It was found that the supply connector at the back of the printer did not have good enough
contact which caused the printer to fail during powerup (during powerup it drows more power when
it turns on the morots...).
Posted on Feb 28, 2009
APremkumar
  • 564 Answers
SOURCE: HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 31, 2009
If you have replaced a toner cartridge recently, eject the cartridge again and reseat it correctly.
Apr 25, 2014 | Dell Office Equipment & Supplies
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
MY HP laserject P3005 printer makes alot of grinding noise but prints fine,is there anything i can do
Hi lexdalex,
Test the cartridge, if you have an old cartridge then insert the cartridge and try running a test print. If the grinding noise is gone, then it is the cleaning blade on the cartridge.
Al
Aug 02, 2010 | Office Equipment & Supplies
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
Mar 18, 2009 | Samsung CLP 300 Laser Printer
When printing, grinding noise occurs
Try a different toner cartridge. If you still get the noise, it will probably be the fuser. They have gears and bearings that sometimes break.
Mar 17, 2009 | HP LaserJet 2200D Printer
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
