Question about Sharp Office Equipment & Supplies
Sharpvison XV-Z20000 lens swap
Can I swap lens assemblys between XV-Z20000 and 12000 MKII
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: SHARP M# = XV Z20000 S# =
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Dec 15, 2010
Scratched lens
Without the right skills and tools it is almost impossible to correct assemble a lens. I'm not sure you can switch over a complete lens assembly, but I do advice to look at ifixit dot com, to see if they did unassembled the S7000 already, Then you can make up yuur mind if you have enough skills (and tools) to do it yourself.
If you don't see anything on the pictures you make, about the scratch, you also cold continue using the camera as is. Most of the time you only see a flair on the picture is a bright light hits the scratch.
Feb 04, 2014 | Fuji FinePix S7000 Digital Camera
Will this lens work with a Canon 5d mkii?
Quantaray makes their lenses with a variety of camera mounts. A lens with a Nikon mount, for example, will not work on a Canon body. As long as you get the lens with a Canon mount, it will work with the 5D MKII.
Mar 09, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Model XV-DV272 only get error message "No Disc" no
Try purchasing a dvd player cleaner, it will have a disc with fine brushes to clean the lens.
May 03, 2011 | Pioneer Televison & Video
Not playing
defective lens....or motor w/c rotates the cd....you can purchase Lens assembly..it is a complete set of lens and motor driver...just look for the code number in the case.....it's better to replace this and it will runs as new.....in case of defective modemn or the PCB circuits..it is also replaceable they just gonna swap it w/ new one..
Feb 12, 2011 | Computers & Internet
Cleaning the lens of a xv-s96u
Open lamp cover and out bulb.Use air blower.It need service
Jan 30, 2010 | SharpVision XV-S96U Multimedia Projector
XV-Z9000u / The picture is clear great but I have no red colors?
first, reset the settings to factory default (through the menu). if you still have no red, swap out the cables. also, check to see if there is any broken glass inside the projector. if you have, the colorwheel is broken and needs replacing.
Oct 13, 2009 | SharpVision XV-Z9000U Multimedia Projector
My sharpvison z9000u is not powering up bulb was used less than 1000 hours
Hi There Sounds like a lamp has died. The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally, @ $US335 for a SharpVision Z9000u Regards Kevin Andreassend http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jun 27, 2009 | SharpVision XV-Z9000U Multimedia Projector
Not recognizing any DVD inserted on my DVD player
dust in lens mean dvd does read! clean the lens with disc cleaner! some problem comes again mean you want to change the lens!
Jul 01, 2008 | JVC XV-S300 DVD Player
FD 200 MAVICa won't focus
Do yopu remember if the front (lens) area received a hit, even though with low force?
I am asking because in most MVC-FD cameras I opened to fix them about the same focus problem, I did find that an internal bracket that holds the lens assembly, it was bent due to an external force or hit in the front.
The bent bracket really was not the problem. The reason of the focus issue was that when the bracket was bent, the flat ribbon cable of the lens was pressed against a mounting screw, causing that the flat ribbon cable was damaged (punctured) affecting 2-3 traces of it, and preventing the lens to operate properly.
Repairing such problem requires to either replace the damaged flat ribbon cable, or the whole lens assembly.
You can get your hands in a broken camera with good lens assembly, and swap the parts.
Best regards,
Feb 25, 2008 | Sony Mavica MVC-FD200 Digital Camera
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
