Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Setup network on a digital sprite 2
Setup network ip on unit from the front panel
  • 3 Answers
SOURCE: Have Digital Sprite 2 with static ip. No network connection.
swap cords, is the lights on in the net jack on the unit, if no then maybe faulty
Posted on Aug 15, 2009
  • 11 Answers
SOURCE: how do enter the password on digital micro
Press and hold the menu button for 5 seconds. This will cause a password screen to pop up. Enter the password if one is required then press menu to go into programming menu. Note: if the unit hasn't been set up for a password simply holding the menu button for 5 sec. will take you into the programming menu. A new password can be set up from there.
Posted on Jan 31, 2010
SOURCE: How to check the IP on Digital Sprite 2?
I have no idea what Digital Sprite 2 is , but one universal way to check an IP of a device is to put it after DHCP server and check that server's IP allocation table.
Most home routers have those DHCP servers built-in and functional, so maybe the real question here is "how to check the IP lease allocation table of my wireless router" :-)
Posted on May 25, 2010
SOURCE: forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Posted on Feb 23, 2011
russ_hill007
  • 3187 Answers
SOURCE: sprite 2,digital recorder
Have you checked the system fans and hard drives as it maybe over heating. the fans don't last long around 15000hrs and stop cooling the system, that makes the hard drives over heat and the system board.... now I don't know why but if the system board goes over 40c inside the system will freeze up cameras pictures will stay on screen but frozen. but if a hard drive fault happens on slave the system will not record but the cameras will still be displaying movement but not record or say live just a red flashing power led. If it does these then change them. if the psu is at lower end of its life the voltage must be checked. the capacitors in side will need changing and the cooling fan you will need a 2200uf 25v/ 2x 470uf 16v/ 3x 3300uf 16v/ 1000uf 16v. and new 12v fan. you should easy spot the ones gone as the tops go rounded. This also may help you to stop problems happening as it has worked on mine. inside the system put a board in-between the hard drive/s and system board leave an inch gap at the end near to the fans. I have found this helps vent the heat out better. you could if you are able to fit some fans into the board. may help cool them down better. now for why the system fails at 40c. the system fails as there is not enough ventilation now normally here in the UK it is fine, but with temp's getting into the 30c's in the summer times, the systems need to be in tip top condition. so replace fans every 2 years and hard drives every 4 years. hope this helps some of you out.
Posted on Sep 14, 2013
I have a Xerox 8560 printer and I am trying to setup the TCP IP address, but the control panel will not let me go in to setup, it just says Exit. When I go into Trouble shooting I can print a printer
The procedure to set the IP address from the control panel is below:
1. On the control panel, press the System button.
2. Select Connection Setup, and then press the OK button.
3. Select Network Setup, and then press the OK button.
4. Select TCP/IP Setup, and then press the OK button.
5. Select DHCP/BOOTP, select Off, and then press the OK button.
6. Select TCP/IP Address, and then press the OK button.
7. Enter the product's IP address, and then press the OK button
Sep 27, 2014 | Xerox Phaser 8560MFP Laser Printer
May 25, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
How do you set the ip address on an IBM 1222
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
Feb 04, 2010 | IBM Infoprint 1222 Laser Printer
How do enter the password on digital micro digital sprite using the front panel buttons
Jan 16, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
My printer went offline; once I placed it back online it will not print
Hi
As you have not provided me any information about the setup and also no information about the unit. However I will still like to perofrm few troubleshooting steps.
If your printer is a HP and is connected in network then I request you to perform below steps.
1. Print a network configuration page from the printer front panel.
A. Press the Setup button.
B. Press the arrow buttons to select Network and then press OK .
C. Press the arrow buttons to select Print Network Configuration Page and then press OK. The Network Configuration Page prints.
2. Note the IP address on the printer.
3. Please open the printers folder located in the control panel
4. Right click on the icon and select properties
5. Select ports tab and click on create new Port button.
6. Select the Ports tab, and then click Add Port. Select the standard TCP/IP Port and create a new port. Type the IP address of the Printer and proceed with the onscreen instructions.
Now try printing.
Yours,
Roger
Oct 03, 2009 | Office Equipment & Supplies
Jun 02, 2009 | Dedicated Micros Digital Sprite 2 RS Video...
Won't record
is the unit setup , sounds like the factory did a reset . go thru dm site for set up and repost
May 10, 2009 | Dedicated Micros Digital Sprite 2 RS Video...
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    Televison & Video Logo
    41 people viewed this question
    Top Dedicated Micros Televison & Video Experts
    CoppellTVRepair.com
    electracon
     Russ Hill
    Russ Hill
    Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
