Question about Zyxel ZYWALL 35 Firewall
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip pinging time more than 500 ms that time browsing is cut.i need solution for this problem.
  • 135 Answers
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Posted on Jul 22, 2009
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
My dsl internet light stays red when plugged into the router, but okay when plugged into my computer
print2.gif print email2.gif email
Title: Setting up Cable Internet for the RV082 Article ID: 16585
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Step 1:
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb16585_001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Step 2:
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
Step 3:
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports.
Step 4:
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
Step 5:
Access the router's web-based setup page. For instructions, click here.
Step 6:
Go to the Setup - Network, click the drop-down arrow under the WAN Connection Type field and select Obtain an IP automatically for WAN1.
kb16585_002_en.png NOTE : If you are going to have another Cable Internet as well in WAN2, select obtain an IP automatically as well.
Step 7:
Click Save Settings.
Step 8:
Check in the System Summary if the router is getting a WAN1 IP or WAN2 IP.
NOTE:
If there are no IP addresses seen in this field, go back to Setup then click the More option to reveal the MAC Clone settings.
Step 9:
Select MAC Address from this PC.
Step 10:
Click Save Settings Button.
Step 11:
Click System Summary. Check the value of the WAN1 or WAN2. If these have numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem.
kb16585_007_en.png NOTE: If the WAN1 IP or WAN2 IP is all zeroes (0.0.0.0) click first Release then click Renew buttons. If the WAN1 IP or WAN2 IP is still all zeroes (0.0.0.0) perform a power cycle.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment.
Step 12:
Once the router is configured, perform a power cycle. Shutdown the computer and Unplug the router's power cable. Unplug the Broadband modem's power cable and wait for 30 seconds then plug in the Broadband modem's power cable and wait for its lights to appear stable. Plug in the router's power cable once the modem's lights appear stable.
Step 13:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router. For instructions, click here .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 25, 2010 | Linksys RV042 VPN Router
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
Wan1 port not working in DFL 800 , can I use wan2
Yes, you will need to duplicate your wan1 configuration for wan2 and then move the cable. If you have any specific problems, please repost and we'll help you further.
Jul 08, 2009 | D-Link DFL-800 (DFL800) Firewall
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
WAN 2 dissconnects
Try check with your subnets, if your subnet on your SBS is the same as your Xincom configuration and both your SBS and XIncom is acting as a DHCP server, it might cause a conflict.
Jan 19, 2008 | Xincom XC-DPG502 Router
Full Duplex
By default, I think these come with auto-sensing turned on, but I may be mistaken.. do not have one available, but do have the manual link if you need it:
ftp://ftp.zyxel.com/ZyWALL_35/user_guide/ZyWALL%2035_4.03.pdf
or:
http://tinyurl.com/2k9gth
I reviewed the entire document and did not see a section on configuring duplex, although it may be in the Bandwidth section.. since they do not show all the configs, I am not sure....
Dec 21, 2007 | Computers & Internet
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Dec 09, 2006 | Zyxel ZYWALL 35 Firewall
Zyxel ZYWALL 35 Firewall Logo
354 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
