Question about Thermador P304CS Gas Kitchen Range
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Electric oven does not heat properly, seems like temperature is not even and if i increase temperature the top crust is overcooked. the oven dials dont match the temperature its about 25 degrees too hot or not hot enough
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Posted on May 08, 2014
fridgetech
  • 473 Answers
SOURCE: oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Posted on Oct 06, 2007
frcs68
  • 1605 Answers
SOURCE: Could you tell me what year this model thermador gas top 6 burner
Thermador PRG stove is build between 2001-2003, $5, 000 new.
depends on the condition of the stove, and the oven. of cause, it is hard to say how much without testing it out. It is like buying a car. need test drive.
Posted on Jan 06, 2009
SOURCE: thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Posted on Jan 10, 2009
SOURCE: Thermador professional
I had the exact same problem. I read someone else turned off the circuit breaker in the electrical panel.. so I tried that. Flipped breaker off for 30 seconds and then turned back on. Oven now works perfectly as before. Go figure??
SOURCE: thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Posted on Feb 09, 2009
Thermador temperature display start temperature
Send back for a replacement,obviously something definately wrong with that gauge reading 200 degrees at room temperature!!!
Jan 08, 2014 | Thermador PDR366ZS Dual Fuel (Electric and...
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
May 10, 2011 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador range electric model ref 30
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador PDR30 4ZS/05 duel fuel
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Thermador P304CS Gas Kitchen Range Logo
114 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
