Question about Eureka Uno 2998AZ Bagless Upright Vacuum
How do i check to see if a motor works thats not fitted
  • 3 Answers
Spin it, it should give output!
(Hint only)
All the Best!
Posted on Apr 21, 2014
Power head not working
Hi, it sounds like your motor is gone. That was the sound i had from my dyson dc07 animal i took it apart and found that the brushes had burnt the armature on the motor. I ordered a new motor and fitted it back together with the help from an espares video. I bought a genuine dyson motor they come in a black box and it is a lot cheaper than buying a new dyson. It was the popping sound that i had .Hope this is of some help to you. Always unplug the hoover when working on it.
Mar 02, 2014 | Dyson Slim DC18 All Floors HEPA Bagless...
Electrical smell, before drop in suction that comes and goes. Working fine till then, happened after I changed from a full bag to empty one. It seems that the motor might have packed up, but why so...
A strong "electrical" smell indicates that the motor is burning out. The cause is possibly worn down brushes resulting in the brush holder/s rubbing against the armature. The motor can be replaced, but I'm not sure what the price would be for parts and labor. You may be better off getting a new one
You can take it to a shop to have it checked to make sure.
Mar 02, 2011 | Numatic Henry Bagged Canister Vacuum
I have a Vacu Queen V3000 and it stopped working in the middle of a job. I verified that I have power at the outlet that it plugs into and then checked motor resistance from the plug and I got about 600...
As a quick test Plug in the vac again and turn on the switch, then try your power head. If the head works you have a motor problem, if the head doesn't you likely have a cord problem.
You seem to be saying it failed while running??? which generally indicates your switch is the suspect.
Check the motor for a worn or sticking carbon brush.
Motor is access by removing the chrome lid and 3 screws under the handle., then removing the paper cone and unscrewing the center screw a t he bottom of the plastic.cone cage...
Dec 12, 2009 | Filter Queen Majestic Canister Vacuum
Decrease in suction
Check to make sure the round gasket seal, under the hood, is in place. It is a rubber seal that sits on the plastic pipe, under the corner of the recovery tank, when the tank is placed in to the foot. It seals the vacuum from the motor, to the tank.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do i fit new brushes in dyson dc 07 have the
you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I change the belt on the motor?
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Hoover U6630-900 WindTunnel Bagless...
Replacement motor wiring-not exactly like the old one
yes but make sure the motors are exactly the same.check the voltage on both of them and see if they are both ac motors and not dc motors.if the new motor is dc it won't work.i have a hoover savvy that has a dc motor that i want to replace with a ac motor
Apr 28, 2009 | Vacuums
Dyson dc05 motor cuts out
Check for either voltage to switch or if your not happy or compettant working on live mains.
Switch meter to ohms ensure vacuum is unpluged from mains follow live wire (brown) from plug to exit point on the back of cable rewinder check for continuity shold be dead short if it is check switch if this is ok move to neutral (blue) wire again check from plug to rear of cable winder.
The neutral then goes off to moter again check for dead short,
I think from experience that you will have A break in either live or neutral in the mains lead going to cable winder.
If it is its realy easy to replace winder they come with lead all ready fitted.
If you need one contact me.
http://dysonmanuals.llc.nu/index.htm
Chris...
Nov 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush motor doesnt work
The cord at the bottom of the power head neck may be bad. But so could the plug connections in the hose handle, and the cord on the wand. Check both ends of the wand and make sure that the plug ends aren't burnt, if they are replace them and maybe the plug inside the hose handle.
Mar 24, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Eureka Uno 2998AZ Bagless Upright Vacuum Logo
19 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
