Code co2oo how to clear it
How to clear a code co200
Minolta cf2001 photocopier, showing error co200.
try a hard reset.
by plugging off the unit from power for one night and then using it again.
Oct 02, 2008 | Minolta Office Equipment & Supplies
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
Cs pro copier EP300
open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
there called charge corona wires mite buy a few!!! they are very easy to break.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
Cs pro copier
Open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
Cs pro copier EP 3000
try this site
Co2oo is my machines
Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. if that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off.:) Open close the front door resets the code.
Aug 26, 2013 | Minolta EP4000/5000 CS/PRO Copier
13 people viewed this question
jasbo
jasbo
