Question about HP Photosmart 2610 All-In-One InkJet Printer
I can't remove ink cartridges from either my HP c5580 OR my c5280.
There seems to be a plastic rectangular piece, blocking the inks from coming out.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Are you following these instructions to remove the cartridges?
Replacing the Print Cartridges
Posted on May 08, 2014
Basti
  • 1447 Answers
SOURCE: how do I install an
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
Posted on May 15, 2008
SOURCE: HP Photosmart C5280 printer - 1 month old not printing correctly
hp c5280 replaced the ink cartridge and the heads will not align, took out an put back in an they still will not align.
Posted on Sep 17, 2008
  • 291 Answers
SOURCE: HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Posted on Nov 23, 2008
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7780 sucking out ink of new ink cartridge
Is this a refillable cartridge you're using or a genuine HP OEM...
If it's a CIS, refillable or some kind of cartridge which is not made by HP then chances are the ink nozzle has failed and allowed the yellow ink to leak everywhere...
There are a lot of problems with these 3rd party cartridges and I would never recommend using anything other than a refilled HP cartridge or a genuine one.
Hope that helps.
Martin
Posted on Jul 11, 2009
  • 111 Answers
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Posted on Apr 13, 2010
I moved and it seems that a plastic piece came loose inside the machine and was laying on the bottom/ It is a rectangular piece and i cannot seem to find the right placement of it. Can you help?
Not a lint filter is it with a mesh bag attached? It may slot into the side of the bowl towards the top somewhere.
If thats not it perhaps you could describe it a little more.
May 21, 2010 | Haier HLP21E Top Load Washer
CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
May 18, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Epson Stylus C88 won't print black ink
You have tried almost all the steps. You have to consult Epson Service Support. Don't try more the head can damage.
Mar 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer error MP 970
try and print another piece of paper and it should come out
or take the ink cartrages out and take the bottem platform off
there should be another box looking thing take it and slide it over
then you should be able to see the paper
Dec 11, 2008 | Canon MP970 Photo All-In-One InkJet...
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Print out very light
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Apr 17, 2008 | HP LaserJet P3005dn Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
