Question about Maytag MAT12CSD Top-Load Coin Operated Washer
Top load coin op F7 code - Maytag MAT12CSD Top-Load Coin Operated Washer
5 Suggested Answers
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Maytag MAT12CSDAW
Try the following on a top loading washer. Prior to opening the lid, find the tiny switch that engages/disengages the water upon lid opening and closing (found on the back right corner of my model).  This is your target! Open the lid. Push the washer drum to the back to access the "real switch" underneath the lid/washer housing.   The switch can be pushed back and forward (this is how it engages/disengages water) or pulled slightly down.  Pull the switch down and close the lid. You are good to go!  Hope this helps!
Posted on Dec 01, 2008
landsend
  • 1066 Answers
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Posted on Mar 11, 2009
Just bought brand new whirlpool top loading commercial washer and dryer with the coin sli
i think the answer is in the question....
you have bought a machine for multiple users (apartment. camping sites)
did you get a key for the coin box?
if so. just keep coins handy run them through the coin-op.
otherwise, you may need to employ an electrician to bypass it
May 16, 2014 | Washing Machines
How to clear maytag f20 error code
Open the top access door and press the black bottom right button for 2 aeconds.put the access door back.
Oct 13, 2012 | Maytag MHN30PDBWW Washer - High...
It is flashing "op" wont start
See if this link will get you started.
http://www.fixya.com/support/t5155274-maytag_neptune_model_fav6800awq
http://www.fixya.com/support/t5958665-od_error_message_when_try_start_wash
You troubleshoot "OP" and "OD" similar. You can place a magnet over the left gray lid bumper with the lid raised and see if that will clear the OP error code with the lid open.
If it does then the lid magnet may be out of position in the inner lid.
You can't pull the Service Manual from Servicematters any more they have placed a coin slot on the site.
Oct 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP MAYTAG WASHER MODEL# MAT12PDBAW
I JUST HAD THE SAME QUESTION FOR A CUSTOMER REQUEST, I TALKED TO THE TECH SUPPORT AT MAYTAG AND THEY EXPLAINED THAT ALL YOU DO IS UNPLUG THE CONNECTOR CC FROM THE PRINTED CIRCUIT BOARD THEN SCROLL WITH THE CENTER BOTTOM BUTTON, TILL YOU SEE 600 DISPLAYED. (600 IS ZERO COINS, 604 IS 4 COINS, 608 IS 8 COINS, ETC.) THEN RECONNECT THE CC CONNECTOR AND PUT IT TOGETHER, SOUNDS SIMPLE ENOUGH. IM GONNA GO TRY IT
Sep 16, 2010 | Maytag MAT12CSD Top-Load Coin Operated...
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Empty washing machine still unbalanced
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Maytag MAT12CSD Top-Load Coin Operated Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
